fan shroud - Ford Truck Enthusiasts Forums
fan shroud
Old 03-18-2010, 07:40 PM
badfl97 badfl97 is offline
badfl97 is starting off with a positive reputation.
fan shroud
Is there an easy way to take the fan shroud off?? I have a 5.4 liter 2004 f-150.
Old 03-18-2010, 07:49 PM
GwarForAll1021's Avatar
GwarForAll1021 GwarForAll1021 is offline
GwarForAll1021 is starting off with a positive reputation.
yea have to remove the radiator to get enough room to clear the fan.
its not going to do anything maybe even hurt. your fan wont draw enough air to proper cool your motor.
Old 03-19-2010, 12:40 PM
Gearbanger 101's Avatar
Gearbanger 101 Gearbanger 101 is offline
Gearbanger 101 is gaining momentum as a positive member of FTE.Gearbanger 101 is gaining momentum as a positive member of FTE.
Quote:
My first question is.....why would you want to?
Old 03-20-2010, 04:23 PM
trying to get to serpentine belt tensioner.
Old 03-20-2010, 07:49 PM
svt2205 svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
You don't need to remove the fan shroud to get into the tensioner. It's a bit of a tight squeeze, but you can do it.
While not necessary for the job he has in store, you most certainly can remove the fan shroud on a 5.4 NBS without removing the radiator. I did it when I changed the fan clutch a couple months ago. Took some wiggling and all, but it will come out and go back in.
Old 03-21-2010, 01:03 AM
Tylus's Avatar
Tylus Tylus is online now
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
just take the fan loose from it's pulley. I used a strap wrench to hold the pulley still, and a huge crescent wrench on the input shaft.
once you have broken that joint loose, the fan shroud slips right out without any issues.
Fan shroud willowbilly3 1957 - 1960 F100 & Larger F-Series Trucks 4 07-01-2016 04:53 PM
F-1 Fan Shroud dongc1 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-08-2012 08:25 AM
Fan shroud for a 351W oft 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-20-2011 04:48 PM
82 f-100 fan shroud 82f-100 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 05-12-2009 03:28 PM
Fan shroud 61 uni 1973 - 1979 F-100 & Larger F-Series Trucks 22 07-13-2007 11:33 AM
Tags
2003, 2004, 20042008, 2006, 2007, 54, engine, f150, fan, ford, removal, remove, shroud
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
