Bronco II Ford Bronco II
engine swap
Old 03-25-2010, 04:49 AM
kernel-panic's Avatar
kernel-panic
kernel-panic is offline
If you can figure out how to mount the tank where the spare tire carrier is - between the frame rails behind the rear axle - and move the fuel tank door. That's about the only way I know to use a Bronco II fuel tank in a Ranger. Did you read the page I linked above regarding the Duraspark conversion? Here it is again:
The Ford Ranger/Bronco II 2.8L Duraspark Ignition Conversion
I believe the connectors you need are still present on the 2nd gen Rangers. I know for sure that they are installed on my '87 Bronco II. You can also Google "Duraspark Conversion Ford Ranger Bronco II" and probably pull several links to write-ups and discussions on it.
Old 03-25-2010, 04:28 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
There must be a limiting factor to the rear tank size on the Ranger P/U, I have a dual tank Ranger and the rear tank is only 12 gal. The Bronco II body must sit higher allowing the 23 gal tank enough room.........just thinking aloud.
Old 03-25-2010, 09:25 PM
kernel-panic
That wouldn't surprise me, Old93! I guess it'd be easier to look at making the stock tank work. Easiest way I know of would be to swap the in-tank pump from a high- to a low-pressure tank.
DylanPalmer
Bronco II
01-15-2013 01:08 PM
NitrousAl
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
04-24-2005 09:02 AM
The Phenom
1983 - 2012 Ranger & B-Series
02-26-2005 12:22 PM
LxMan1
01-27-2004 10:21 PM
bumpin_BII
01-30-2003 01:29 PM
Quick Reply: engine swap
