anybody know about airconditioning
From the pictures I don't see too much damage to th a/c condenser, if it is not leaking you can pull the condenser away from the radiator and get a little space between the cooler and the radiator. You can use a fin comb to repair the condenser. It should be ok. If it is leaking all bets are off. those condensers are soft and can be sprung fairly easy, but you will have to open the fins up for air flow. I may be way off base here, hard to see in the pictures. my .02
Stop sign a 4 wheel one or a 2 wheeled one? lol. Id just replace it. 134a is kinda expensive. And if you do decide to replace it. May as well flush your system to all the crud that built up in there over the years out. Oh yeah one more thing, go to your local parts store and buy the dye that goes into it. Your goin to need glasses and the pen to see if its leaking or not.
when i replaced my condensor due to it being beat to hell by large bugs i put on a new condensor and then took it to the local guy who had to vacuum the system and i also replaced the drier and had the shop recharge. the condensor was like 130 on ebay about 35 for the drier and about 110 for the shop to vacuum and recharge the system......
If it's leaking, it needs to be replaced, along with the dryer, vacuum it down, and recharge. Pretty straight forward.
on
1 Post
Like CPUNEK mines is beat all to hell and has a bend in it. No problems for a long long time. I was worried about it but figured I could watch for leaks and see how it did. No worries after hitting a deer and pushing fog lites back into the condenser. AC cools just as before and all is well. If I have AC problems in the future I figure I'd deal with them all at one time. As long as the system has to be broken into, might as well do it just once.
Sounds like you may have too much spacing on your a/c clutch. the clutch face needs to be about .030 away from the pulley face, there are shims behind the clutch that can be removed to close the space up. with too much of a gap the clutch will not pull in.
couldnt get it bent back straight enough to fit 6.0 tranny cooler in without messing it up even worse got it vacuumed out today only had 1 pound in it so i guessing it was leaking this all happened because i was looking at a lawn mower lowes turned back forward and STOP ins would cover but i will have it fixed for around $600 thats only $100 more than deductable then no raise in rates either oh by the way it was a concrete encased stop sign didnt even knock it loose no more looking at lawn mowers while driving in parking lots
thanks for all the advise
