Speed Limiter ?s (want real answers, not lectures) - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 03-19-2010, 05:03 PM
2ndmouse's Avatar
2ndmouse 2ndmouse is offline
2ndmouse is starting off with a positive reputation.
I'm mechanically ford stupid.
What's a speed limiter?
  #32
Old 03-19-2010, 05:06 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
I really hope ur kidding.. But if ur not, it "shuts down" the vehicle at a set speed. In the case of my 94, its 95 mph.
  #33
Old 03-19-2010, 05:12 PM
2ndmouse's Avatar
Nope, I'm serious. I learn a lot reading this forum.
Thanks for the answer, now I know.
I learn something every day here.
  #34
Old 03-19-2010, 05:24 PM
wickedklown83's Avatar
wickedklown83 wickedklown83 is offline
wickedklown83 is starting off with a positive reputation.
i agree, i could not imagine pushing a full size that fast personally, but i know i push the speed limiter in my little ranger constantly, unfortunately it shuts down at 104, a real bummer. hope you can figure something out and if you do hopefully no idiots decide to pull out in front of you, thats the biggest issue i have in my ranger pulling triple digits
  #35
Old 03-20-2010, 01:56 AM
truckrider814's Avatar
truckrider814 truckrider814 is offline
truckrider814 is gaining momentum as a positive member of FTE.
It aint bad in a full size truck quite fun if your out on open road with no traffic. I've had her up around 110mph. I dunno but you gotta love the older trucks without computers and stuff, i have yet to hit any kind of limiter on mine speed or rev.
Kyle
  #36
Old 03-20-2010, 10:11 AM
DJdemon6696 DJdemon6696 is offline
DJdemon6696 is starting off with a positive reputation.
i think to get what you want. you need to call superchips or places like that to have them to make a chip for you that removes the speed limiter..
  #37
Old 03-20-2010, 10:36 AM
Ed Bamba Ed Bamba is online now
Ed Bamba is starting off with a positive reputation.
Quote:
Not sure if it shuts down the engine, or if it just alters the spark signal or fuel delivery output. Since you are set on going fast when you feel the "need for speed" don't forget about the "Whoa" pedal too. It should go without saying that you need to be concerned about slowing down as much as going fast. BTW, not a lecture, just mentioning the braking concern just in case you haven't done so already.
  #38
Old 03-20-2010, 10:54 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
No it does not shut down the engine or do anything to the Ignition system.
What it does is lock the clutch in the TQ and shut off half of the injectors.
That is why some trucks will start and idle but as soon as you put them in gear the engine will die if they have a bad VSS or PSOM. If you look at the speedometer at the same time they quit it will be pegged out.
This applies to 1992-1995 trucks.
  #39
Old 04-06-2010, 09:15 PM
Duramaxfanatic1's Avatar
Duramaxfanatic1 Duramaxfanatic1 is offline
Duramaxfanatic1 is starting off with a positive reputation.
had the speedo on my 88 pegged out one time. no idea how fast i was going but it was a slow crawl there YouTube - old slow f250
  #40
Old 04-06-2010, 10:25 PM
SaikotikGunman's Avatar
SaikotikGunman SaikotikGunman is offline
SaikotikGunman is gaining momentum as a positive member of FTE.
I pegged out the '88 on I80.
  #41
Old 12-01-2013, 03:37 PM
jshk87 jshk87 is offline
jshk87 is starting off with a positive reputation.
[QUOTE=hav24wheel;8660792]I really hope ur kidding.. But if ur not, it "shuts down" the vehicle at a set speed. In the case of my 94, its 95 mph.[/Q
I got pulled over and the cop wrote a fine saying i was going 120 mph in my stock ford f150 4.2L i was wondering when the governor kicks in
  #42
Old 12-01-2013, 04:15 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
Just curious, does your truck have a factory tach? I had a 94 F250 XLT 460 that would run over 110. We were on our way to Colorado and got in a race with some other guys we knew out across Kansas. His car (some kind of Chevy) crapped out at 108 and we walked off and left him. This truck had a C6 trans and no factory tach (or any tach at all, for that mater) and was wound TIGHT when I let out of it. Finally decided to part it out at 321,xxx miles when it blew a head gasket. I haven't taken my similarly equiped 89 that fast cause it's to scary! That 94 drove like a sports car. Will it run faster in 3rd gear than OD? Just thinking...........
2010 Expy Limited captn chairs want to add middle expoman55 2007 - 2014 Expedition & Navigator 1 01-12-2014 12:15 AM
Tire size question and RPM Question? bwnelson 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-28-2013 03:03 PM
NAV question PITS 6.7L Power Stroke Diesel 7 05-26-2011 10:39 AM
Smooth Moments with Keith Stone - Double Posting Talyn 1994.5 - 1997 7.3L Power Stroke Diesel 17 04-01-2011 11:36 AM
What speed does your truck limit at? TwIsTeD OfF 6.4L Power Stroke Diesel 16 02-08-2008 06:13 PM
Tags
1996, 1999, 94, 96, 97, decided, f150, f250, ford, fords, governor, idiot, kick, limiter, limiters, ranger, set, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
