5 SPEED
03-17-2010, 11:44 PM
on
5 SPEED
I have a '77 F-150 and i'm looking for a 5 speed for can anyone point me some where to look or find one? it would just be nice to be able to go 75 with no worries. which i can not do with a 4 SPEED!!!! SUCKS!!!!
Cheyenne, WY
03-17-2010, 11:47 PM
on
.....knowing your engine would be helpful.
What engine do you have?
-John
03-17-2010, 11:49 PM
on
oh sorry my bad. it is a 351/400M. f-150
03-17-2010, 11:56 PM
A ZF out of a 87-97 F 250/350 with a 460 would work, but you will have to fabricate up a hydraulic system. You will have too adapt your transfer case to fit and get different length drive shafts.
-John
03-18-2010, 12:02 AM
on
ok thanks that helps alot have you heard of anyone doing that?
03-18-2010, 12:04 AM
Pretty sure a few guys around here have done it but I haven't, I like the 4spd.
-John
03-18-2010, 12:06 AM
on
ok cool do you know if it was hard or just like everything on a truck just time consuming?
03-18-2010, 12:13 AM
It will involve some fabrication because this truck never came with that transmission from the factory so you have to make some stuff. First you will have to find a way to make your clutch peddle hydraulic instead of mechanical, you will have to make a cross member because the transmission mount is different, and you will have to find an adapter to bolt your new transmission to you transfercase and move your transfercase mount too. If you wind up moving the transfer case which I am pretty sure you will you will need to get new drive shafts of have you current ones changed to the right length.
-John
03-18-2010, 12:18 AM
on
Actually, if his truck is a 4x4, the transfer case will bolt right up. Also, the ZF-5 uses an external slave cylinder. A mechanical clutch can be used.
03-18-2010, 01:14 AM
While the t-case will bolt right up, it requires a small bit of grinding to clear a shift rail.
Thid depends upon which adapter is actually used. The later one will require some work.
205 behind a ZF:
03-18-2010, 07:24 AM
you cant hit 75 with your 335 series motor?? i can understand wantin the rpms down, but it sounds lik youre unable to get to 75...
03-18-2010, 10:00 AM
Normal for the 335 series. lol
03-18-2010, 11:01 AM
you would say that... lol.
03-18-2010, 06:59 PM
on
I have done this swap and am using the stock mechanical clutch linkage, as well as the stock length driveshafts. Check my gallery for some pics.
