EGR Valve, Removal, Cleaning...
CEL made an appearance today...Last week the little booger came on, check out things..thought maybe fuel pressure...Looooong story short, I ended up replacing the fuel pump and changing the filters. Fired right up and CEL went off.
So...driving today it came back on, pulled into Auto zone, they pulled codes P1335, and P0404. Both related to EGR problems (valve sticking open, etc.)
Called Dealer and reserved my valve at a modest 208.00 (not bad I thought), also bought the gasket kit. My original plan was to pull the valve, clean it, replace the gasket and o-rings, reinstall and be on my way. I went ahead and bought a new valve (just in case) I'm going out of town tomorrow and this is for my wife's EX, so she couldn't be without.
Pulled valve...it was dirty, cleaned it up nice, reinstalled, cleared the codes and everything is great again.
One question...my coolant seemed low (took 36 ounces to get full again), could I have coolant leak that doesn't show on the ground...if so where did my coolant go? (it did not get blown out, no residue)
P.S. I have photos but cannot seem to find a way to post them, they were taken with my iphone and are not on my mac in iphoto...any help with that and I'll post before and after pics. Thanks
For the OP
Your pics are small because you used the wrong forum codes. You accidentally selected the thumbnail codes.
Here is your first pic:
Regarding your coolant loss, you may have a leaking EGR cooler. That coincides with your EGR valve being gunked up. When they leak, the coolant goes out through the exaust, unlike leaking head gaskets which will usually blow out the degas bottle. That coolant mixes with the normal carbon buildup in an exhaust system, and turns into carbon paste gunk.
To try to nail this down, park your truck with the nose down and the tail up. Pull the EGR valve again and look down the hole for signs of wetness or even pooled coolant. That will be a dead giveaway that you are blowing coolant into the exhaust stream.
Sorry for the confusion...what I meant by "not blowing out" was blowing coolant out of the degas bottle (common with head gasket leaks).
Besides my pesky oil drip (that keeps coming back after numerous trips to the dealer) there is no evidence of the coolant leaking.
Now, after pulling the valve, I did not see anything moist down the manifold. It was thick, paste like consistency. I took a screw driver, and very carefully broke it up sticking the vacuum all the way to the bottom each time a broke some loose. I got most of the gunk from the bottom of the hole. I didn't have a good brush to get it really clean, although if my cooler is leaking I wasn't too motivated to spend all day cleaning knowing that I might have to take the EGR valve out again in the near future. (that is why I didn't put the new one in yet).
I thought about pulling the EGR on my truck (2006 250 with 75K) and compare. My truck (knock on wood) has been a dream...ofcourse the only mods I have done are replace the speakers, nothing to the engine.
lets try this
https://www.ford-trucks.com/forums/p...ictureid=29361
https://www.ford-trucks.com/forums/p...ictureid=29363
thanks, bpounds...now if I can only get them to show up in the text !?!
lets try this
My EGR valve was very oily and sticky at first also. The ccv re-route, a new EGR valve (updated design), the most recent flash update, and fuel cetane booster each tank - now what coats the EGR valve is just a dry powder (as it should be).
I would be concerned about the coolant loss. It can be the result of a number of different issues, several of them are expensive. Are you sure that you did not see any coolant underneath the EGR valve?
UPDATE.... CEL came on again today, 4 codes (P1335 and P0404) they showed up twice.
This is two days after taking out EGR cleaning (see above) and reinstalling. Should I just put in the new EGR and see if that solves the problem, or take it to dealership and see if there is another cause to the problem (leaking egr cooler, etc.) I really do not want to put in a brand new EGR and then something else cause it to fail. Any help is greatly appreciated!
Just to be different, I would probably put in the new valve. Nothing I can think of is going to damage the new valve, and it probably is the reason for the P404 FC.
The problem with taking it in is that you already dove into it and cleaned up the valve. Techs don't appreciate getting a job that has already been half-assed by the owner. It often makes their job to diagnose just that much more difficult. Not necessarily the case here, but you bought the valve, and you know how to install it, so why not give it a try?
