Air conditioning problems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-17-2010, 08:03 PM
GRN250 GRN250 is offline
GRN250 is starting off with a positive reputation.
So I recently bought this truck a 1997 Ford F250 4X4 5.8L and I noticed that after driving it for a week my AC crapped out I replaced the compressor and the compressor clutch yesterday AC worked great for a day got in the truck this morning and AC was blowing hot air so I went to refill the freon the system seemed to be taking freon but never got Cold. I noticed that the charge port (low side) was leaking so I removed the valve (with pressure on it causing freon and oil to go all over the place) and replaced it; if I recharge the system and it is still not blowing cold air what could be the problem?
I believe that the person we bought the truck from over charged the system causing the compressor to go bad.
How much freon should the system take if it is completely empty and would i need to add more oil if so how much?
Does anyone know a good AC mechanic here in the Houston Texas area if I can't solve the problem?
Old 03-17-2010, 10:06 PM
superdutyduck's Avatar
superdutyduck superdutyduck is offline
superdutyduck is starting off with a positive reputation.
did you do the compressor yourself? if it still doesn't get cold, probably have a dirty evaporator. you have to remember 134-A will not get as cold as r12. could also have a plugged oriface filter.if you did the comp. yourself, you would have had to add the correct amount of PAG oil. and the amount of refrigerant you need should be on the radiator support with all the other little stickers.
Old 03-18-2010, 08:58 PM
I appreciate the input; went to replace the orifice tube and noticed that it was pushed way far in the line and now it looks like i may have to replace the evap. core. Has anyone ever replaced a evap. core how hard is it to replace i have an ok mechanical background? Are there any special tools one may need? Please any input would help me out alot.
Old 05-26-2010, 10:45 PM
farva22 farva22 is offline
farva22 is starting off with a positive reputation.
ac only works on high
i have a 99 f350 ac and heat only works on high does anyone know why.. i have already changed the switch. and i am currently going out of town and need to fix it just wanted to know if anyone had any ideas thanks
Old 05-27-2010, 11:10 PM
replaced the one i my 94 bronco and it was easier than changing the heater core.
AC will not take freon tolmite 1999 - 2003 7.3L Power Stroke Diesel 15 06-09-2014 11:34 PM
A/c Blows warm muddingirl81 Cooling, Heating, Ventilation & A/C 3 09-03-2013 06:30 PM
Need ac trouble shooting help 94 f150 jllaco 1987 - 1996 F150 & Larger F-Series Trucks 18 05-30-2013 12:57 PM
Need AC trouble shooting help 94 F150 jllaco Ford Inline Six, 200, 250, 4.9L / 300 7 05-25-2013 12:27 AM
2006 expedition AC blow off valve thecrow Cooling, Heating, Ventilation & A/C 16 07-20-2012 02:38 PM
Tags
97, ac, air, clutch, compressor, conditioner, conditioning, correct, direction, duty, f250, f350, ford, orifice, problem, problems, super, truck, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
