2004 F150 Triton V8 - Oil Change? - Ford Truck Enthusiasts Forums
Old 03-17-2010, 04:00 PM
TheEif83 TheEif83 is offline
TheEif83 is starting off with a positive reputation.
What is the best synthetic oil to use when changing my oil? I've heard different people I know tell me different types but I would like to get your opinion on this, seeing how you are the Ford Truck guys!
Old 03-17-2010, 04:39 PM
NASSTY's Avatar
NASSTY NASSTY is offline
NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.
Motorcraft 5w-20 synthetic blend.
Old 03-17-2010, 06:02 PM
osbornk osbornk is offline
osbornk is gaining momentum as a positive member of FTE.osbornk is gaining momentum as a positive member of FTE.
Quote:
Ditto! $2.77 at WalMart
Old 03-17-2010, 06:15 PM
YoGeorge YoGeorge is offline
YoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to behold
Quote:
Motorcraft 5W20 syn blend is great, for the price. My last 4 changes, though, have been with Quaker State 5W20 Torquepower full synthetic because I got 24 quarts for 99 cents each. With Motorcraft 820S filters, that's about $10 for a full syn oil change and it works for me (a semi-retired cheapskate).
Now that the last of it is in my crankcase, I will either go back to the Motorcraft or might try some Pennzoil Platinum or something like that IF I can find the right deal.
Any major brand full synthetic (Pennzoil, Castrol, Valvoline Synpower, Quaker State, Mobil 1, Motorcraft, etc) would probably be just fine in the correct weight if you really want to go full syn. I have to admit that my 4.6 really likes the Quaker State, uses just about zero oil between 6-7000 mile changes with 80k on the motor. (I would change the syn blend a bit sooner, maybe 5000 miles, myself.)
If you want to adopt the "designer motor oil lifestyle" or make motor oil your religion, you could go hang out on bobistheoilguy.com and see what the oil of the week is. IMO, they're all just fine.
George
Old 03-18-2010, 12:39 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
You will be good with Motorcraft semi syn. If you want a full syn, PP or Mobil1 are your best balance between price and performance. Personally, I use either PP or Mobil1 in both of my trucks. I buy whichever one is on sale when I need an oil change.
Old 03-18-2010, 12:42 AM
mercman86's Avatar
mercman86 mercman86 is offline
mercman86 is gaining momentum as a positive member of FTE.
Ive run the motorcraft semi-syn 5w-20 and a motorcraft filter since my truck was brand new. 83,000 miles later and the oil comes out almost as clean as it goes in.
Old 03-18-2010, 12:53 AM
Gearbanger 101's Avatar
Gearbanger 101 Gearbanger 101 is offline
Gearbanger 101 is gaining momentum as a positive member of FTE.Gearbanger 101 is gaining momentum as a positive member of FTE.
Which one is the best??? Why, whichever one is on sale of course.
Old 03-18-2010, 07:12 AM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
I have seen Motorcraft 5w-20 full synthetic at an Advance Auto for just under $5. That's a good price for full synthetic. I would stay with the FL820S filter.
Old 03-18-2010, 09:07 AM
goingape goingape is offline
goingape is starting off with a positive reputation.
I always liked Mobil 1 5w-20 Fully Synth
Old 03-18-2010, 10:09 AM
BirdmanStyll BirdmanStyll is offline
BirdmanStyll is starting off with a positive reputation.
Yeah same hear Mobil1 all the way. Cost me like 70$ to do a change but my Ford loves me
Old 03-18-2010, 11:07 AM
edub32's Avatar
edub32 edub32 is offline
edub32 is starting off with a positive reputation.
Quote:
Where'd you get that oil for that price??!?!
Old 03-18-2010, 11:18 AM
Quote:
This was a one-time closeout at Advance Auto almost 2 years ago. I bought all they had (kind of a no-brainer). I think they were discontinuing carrying it and I came into the store on the right day.
I also have the remnants of some Valvoline Synpower 5W30 I'm using in one of the cars that was a buck a quart after rebate at Murray's (now O'Reilley's). Again, that was a while ago.
Doubt I'll ever find full syn for a buck a quart again, but it sure was a good deal when I could. Really, it was $10 for a full oil change including a $4 Motorcraft 820S filter.
George
Old 03-18-2010, 03:26 PM
aft2005exp aft2005exp is offline
aft2005exp is starting off with a positive reputation.
2005 Exp EB 4x4 w/ 96k miles.. Second owner, every since I had it been running the MotorCraft partial syn in it. No problems, and most affordable at Wally World (WalMart) can't beat the price on the jug o'oil and filter.. just my opinion tho...
Old 03-19-2010, 09:29 PM
Quote:
How can you tell? Mine didn't tell me or act any differently.
Old 03-19-2010, 10:24 PM
bigdaddyII's Avatar
Dont know where you get your oil from but last I changed it with Mobil1 it ran me $38. Truck didnt even notice the difference.
Synthetic oil popatop500 Modular V10 (6.8l) 109 12-27-2016 09:28 PM
300 I6 240 I6 Oil ColeT24 1967 - 1972 F-100 & Larger F-Series Trucks 3 02-16-2015 10:11 AM
5W20 or 5W30 and Filter ? for 6.2L RRRAVEN 6.2L V8 7 04-05-2014 09:20 AM
Fram Oil filters 93F250 Modular V10 (6.8l) 50 08-12-2008 11:39 AM
PH8 vs. PH8A oil filter Beanscoot Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 06-10-2007 02:09 AM
Tags
03, 04, 2004, 42, 54, change, f150, ford, oil, specs, triton, v6, v8, weight, wieght
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
