In line fuse amps
What size wire are you going to run? And what are you going to plug into the cigarette lighter?
The fuse protects the wire.
The wire supplies the power needed.
So, the tach is not going to use much, but maybe later you will add some more stuff to that wire? If you run a 16 gauge wire to the tach, I would put a 10 amp fuse with it.
If you run a 16 gauge wire to the lighter, then you will also be limited to a 10 amp fuse, and 10 amps to whatever you plug into the lighter.
If you want to run more power to the cigarette lighter, then here is a general idea of what it will take.
16 gauge wire= 10 amp fuse
14 guage wire= 15 amp fuse
12 gauge wire= 20 amp fuse
10 gauge wire= 30 amp fuse
Steve
Yes, if you have a large fuse on the supply side, and a large load on the other end, and a small wire inbetween, the wire can overheat.
The specs I listed in the previous post are conservative. You could probably run more than 10 amps on a 16 gauge wire. But we are not on a assembly line producing millions of vehicles and spending millions of dollars on copper wire, so we can afford a little bit larger wire. Being conservative on the wire size means less voltage drop through the wire, and less wire heating.
brkncly
6.4L Power Stroke Diesel
09-15-2012 09:47 AM
Redonkulous BOB
26
11-28-2011 02:07 PM
billy jolliff
1978 - 1996 Big Bronco
04-05-2004 05:09 PM
JoeBob1901
13
01-15-2004 08:04 PM
