Rear Hatch actuator
  #31
Old 09-26-2011, 12:48 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Originally Posted by jeeplj8
What aftermarket one did you get? Any links?
not too worried about it being noisy, if it works.
i purchased it in 93 so i dont remember, will post install pic later
  #32
Old 09-27-2011, 12:18 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
heres the pics.
  #33
Old 09-27-2011, 12:21 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
heres a pic from the other side
  #34
Old 02-03-2012, 03:01 PM
Fuha's Avatar
Fuha
Fuha is offline
Sorry to dig up an old post but thought it would be better to post on the same issue then to start a new post.. I torn this apart last night about 4 hours after buying my X to see if i could physicaly see the issue. I can hear the actuator but nothing moves but a little twitch. Also. the metal rod that attaches to the key lock just slides thru that metal peice that it goes in. In b-uno post above this one picture 1 were the blue keeper is. Is that normal. Almost seems like there is a stopped missing on the backside of it. I dont mind replacing all parts with new if thats what needs to be done. As this is the only door that I CAN NOT lock on my X. I got two Actuators that I know I need to replace in the rear doors on both sides. Thinking about doing all 5 and be done with it, or replace what needs to be replaced?
  #35
Old 02-03-2012, 03:07 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
welcome to the world of the new "reliable" cars. anyhow the blue thing i think your talking about looks to me to be just a bushing so it slides smooth on the rod.
  #36
Old 02-06-2012, 12:11 PM
ChoctawChuck's Avatar
ChoctawChuck
ChoctawChuck is offline
Originally Posted by b-uno
well i forced my way thru the stuff in the back and used my 25 torxx to pull that handle off then gorilla pulled the plastic surround off breaking some clips. oh well im getting really frustrated with these actuators.. so now im trying to undo my superglue and bolt i put in the actuator to get it apart from the last repair and fix it again and reinstall it, i think im gonna order a brand new one or 2 and replace them when they come in, but i need one now for the rear hatch as its a major pain to crawl thru the back full of junk.
well heres the actuator motor completely melted down inside, i think the tinfoil mod is a last ditch effort because if it goes again with the tinfoil its done for good it looks like! dang. oh well time to order a new one, but first im gonna try this aftermarket actuator i got laying around and see how it works out.
I believe that you can buy and just replace the motor. I will try to find a source, but you might try your local hobby shop, or go on line.
  #37
Old 02-09-2013, 08:54 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
well dang it going back to stock, just due to the noise of the actuator, it actually worked very good and reliable.
for the life of me i cannot find that @##!!!! dam yellow bushing! i need one to make the stock actuator work again!
anyone got one?
  #38
Old 03-14-2013, 10:36 AM
bwguardian's Avatar
bwguardian
bwguardian is offline
Well, we went on a spring break trip with the kiddos and the locks were working...I think...mid stop on our trip. We get to our destination and I notice none of the locks will work with the key pad or the inside door switch. I can here some sort of module working behind the dash around where the radio area is when I push the button on the key pad. I figured I would just lock the doors manually so that worked until I got to the passenger side front door and it was jamed such that I could not lock it with either the inside lever or the outside key. I wound up pulling the door apart and finding the actuator was frozen so I removed it and hooked everything back up since we were out of town and would be going to Sea World the next day. I thought once I removed the actuator that the other locks would work with the key pad and/or the switch but nada. I am wondering if anyone here has had this happen before...it has been a year and a half since I did the tin foil mod and wondering if the motors might now be toast in the rest of the actuators.
  #39
Old 11-05-2013, 11:59 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Stock new actuator getting weak again! Gonna jus unhook the wire and use the key, these things are garbage. Not worth getting stuff stold out of it thinking it locks
  #40
Old 11-07-2018, 09:11 PM
admyank's Avatar
admyank
admyank is offline
I am confused. Can the left side door actuator work in the rear? I keep hearing grumbles.
  #41
Old 11-09-2018, 01:03 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
i did end up replacing it again, and its working. the keys good untill the back hatch is covered in ice and the key hole freezes up. or i get to lazy.
rolsen333
1997-2006 Expedition & Navigator
05-19-2015 10:14 AM
FordManiac88
22
05-21-2011 08:27 AM
Duct Tape Racing
Offroad & 4x4
04-20-2011 02:07 PM
Kendrick
08-05-2010 08:09 AM
TheBigBee
1999 to 2016 Super Duty
30
02-08-2010 10:09 PM
Quick Reply: Rear Hatch actuator
