Starter switch Motorcraft SW-583 Problems
Old 03-16-2010, 08:45 PM
gamiochipi's Avatar
gamiochipi
gamiochipi is offline
4wd Low
I am trying to install this on my 65 ford truck but I dont know which post is what. Can someone please let me know which(BAT, IGN, S, ACC) is what so I can correctly install it on my truck.
Old 03-17-2010, 09:49 PM
theejohnnyb's Avatar
theejohnnyb
theejohnnyb is offline
Can't you just check the closed circuits with a test light and battery? Turn the key on acc-check circuits, on run-check circuits, have friend or tape hold start-check circuits? Think or write it down if needed. One being separated from the others and the sweep of the key might offer clues too. Good luck, I am sure you can figure it out.
Old 03-18-2010, 04:24 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The problem (and has been for decades) is...that C7UZ11572A (Motorcraft SW583) is not the original ignition switch for a 1961/66.
It's the FoMoCo Service Part Replacement for the original 1961/66 switch: C3AZ11572A (Motorcraft SW353).
SW583 has an extra wire terminal on it.
The original applications for SW583 were 1967 Econolines & 1967/77 Bronco's.
Old 03-18-2010, 05:46 AM
sammycooks's Avatar
sammycooks
sammycooks is offline
Old 06-28-2016, 03:33 PM
walt460's Avatar
walt460
walt460 is offline
The post is for accessories. It is hot in "Accessory" key position and is hot in "Run" position.
B is power in, hooked to battery side of starter relay.
D is Run, hot in "Crank" and "Run" positions
C is crank/start so it is hot only when switch is in "Crank" position
A is not used?
ctorres
10-18-2017 06:44 PM
Broncridinfool
09-06-2017 09:19 AM
scottlathrop
07-02-2017 11:36 PM
ihateminimumwage
Electrical Systems/Wiring
09-26-2016 12:58 PM
likeagoodbook
06-13-2016 07:59 PM
Quick Reply: Starter switch Motorcraft SW-583 Problems
