Removing fin fan shroud for good?
#91
I reserecxted this old thread not to continue the argument but the last 2 posts deal with the legal liability. While a shop useually bears most of the responsibility. certain repairs made by an individual on his own vehicle can be held personally responsible if the vehicle gets in a accident especially if there are injurys.
An uncle of mine changed the brakes on his car but didn't change the back brakes [thinking they were less than half worn]. He had a accident a few weeks later. There were 3 injured serieously and 1 of them later died. The accident really wasn't his fault the other car ran a red light while he was in the intersection. But because of those rear brakes.
He was faced with a wrongful death suite and lost due to not changeing the rear brakes.
Investigation proved that the rear brakes were a littie more than 60% worn.
His lawyer tried the arguement that he wasn't a professional mechanic and didn't know they were beyond legal limits.
The prosecution came right back with one of the first laws on the books.
IGNORANCE OF THE LAW IS NO EXCUSE. That is a actual statute in nearly every jurisdiction that I know of not just an old saying.
#92
60% worn, so 40% left? That's asinine. 40% is way inside expectable limits and should make next to zero difference in stopping distance. We are talking about lawyers here so I believe it though.
The guy that trained me taught me to take them off. He was a ford diesel tech from the IDI era all the way up to '09. There were weeks we would have 15-20 in the dumpster. He said he never put them back on at ford either. I left that shop last year but I've still been leaving them off.
After reading this thread I'll be rethinking that.
#95
Is there a video out there???
I would love to be able to it in even three times that time... and yes, I am NOT ASE certified, shade tree certified, etc...
I am not mechanically inclined and have used this site to learn who and where to go to get my beast to perform better than OEM with all the tutorials. So went I went to Diesel shop of my choice and was able to converse WELL about all the mods and quirks of the 6.0 and they knew I knew what I was talking about and what I was concerned about all because of this Forum.......
That being said, THIS Forum has instructed me very well on smaller things this non-mechanic can do , and I thank all of the more senior members/techs that have been patient with my many questions a couple years ago when I bought my first Diesel....
Alan from San Diego
#96
IMO the only thing that is hard about the belt change is putting the new belt on. In my 06, I rotate the tensioner and lock it, and then remove the old belt. Then to install the new belt it is easier for me to remove the tensioner completely (still locked in position), route the belt, then re-install the tensioner. Then pull back on the tensioner to release the lock.
A long time ago, I bought a tensioner tool that had the square drive at the needed angle relative to the handle - which made the process a lot simpler. It is thinner than a ratchet/socket, or a breaker bar, or a torque wrench. Many people just pull on the belt to move the tensioner and then reach down and lock it. My shoulder does not let me do that.
Edit -
I have heard that this works also:
http://www.craftsman.com/shc/s/p_101...pentine%20belt
Edit -
#97
I built a tool that fits in the tensioner. Welded a half inch end from an old ratchet or breaker bar onto a piece of rebar. It took a few tries to get the phasing right. I slip a bottle jack handle over it, so as soon as it clears the frame etc I can really reef on it. I put a new tensioner on when I rebuilt the engine, and it doesn't have the locking clip.
#98
on
They answered your question in their first reply.
Now answer my question show us your experience and credentials.
While credentials may not be the endall. The ASE test is about 6 hrs long and pretty comprehensive. Think the [ SAT] test but only covering automotive subjects and proceduers. Not a cake walk at all.
If you can even finish in the time alotted you have shown considerable knowledge of the subject, never mind passed or not.
One thing you can't do in this forum is blow smoke up anybody's *** without getting called on it.
Everyone who replied to your posts have a lot of experience whether pros or just gifted amatuers and there are quite a few pros on here.
As to their being friends of mine I wish they were, but I give credit where credit is due
But none of us blindly agree with each other.
#99
Edit -
Serpentine Belt Tool: Get it Done with Sears
Edit -
#100
#101
All it is is flat bar with the appropriate square drive at the proper angle.
Works quite well.
#102
I have never had the "opportunity" to have to change the belt on my '06
Alan from San Diego
Alan from San Diego
I recently replaced the belt on my '06 for the first time, and what I found was that, once you remove the old belt, installing the new belt is much easier if you start from the pulleys just below the tensioner and work your way counter clockwise, finishing up with the alternator.
I tried working in the clockwise direction at first, since this seemed to be the path of least resistance, but when I reached the pulleys just beneath the tensioner, it was nearly impossible to route the belt through because of how tight the space is and how the belt wraps around the pulleys.
You will need to work back and forth from top side to underneath the truck to get the belt on, but it really isn't that difficult, and you don't need to remove any of the fan shroud or pulley to do it, however it does help to remove the top part of the shroud that snaps on. Just a flat head screwdriver will pop it off easily. I'd say 10-15 minutes if you take time to enjoy a cold beverage during the process.
#104
While we're on the subject, does there already exist a step-by-step-how-to or video showing how to get the shroud/stator out of the way for work on the front of the engine "the easy way"? If so, could yall point me to it. If not, could one of yall experienced guys tell us the easiest way. I've been poking around searching here at FTE but haven't found it yet.
I went to put in my new alternator in and discovered that my belt tensioner is seized. So now the project is on hold while I order a new tensioner(amongst other stuff). It'd be nice if accessing the tensioner turned out not to be as bad as it looks.
cheezit & mchan, I dare you to try helping.
And make sure you respond in a way that is guaranteed make me feel good. Otherwise I may be forced to hurl unwarranted accuations and insults at you while demanding you excercise your maximum depths of grace towards me and shower me with accolades for my scant credentials and reputation.
......but seriously, THANKS for all your help!
#105
