Charge Air Cooler leak - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 03-16-2010, 07:51 PM
Champ198 Champ198 is offline
Champ198 is starting off with a positive reputation.
Hi everyone,
I have an '08 Job #1 truck. I found a leak (oily substance) leaking from the bottom corner (passenger side) of the charge air cooler a couple of weeks ago. I wiped it with a rag and it came back. It appeared to be originating from the welded corner of the CAC.
The dealer replaced the charge air cooler and I have the new 7C3Z-6K775-B CAC. (I also have the white smoke on acceleration in damp weather issue which the new CAC is supposed to address)
I'm not a diesel gear head, but my question is what is that much oil doing in the charge air cooler?? Dealer says "normal".
Thanks!!
DH
Old 04-05-2010, 09:14 PM
Medic 66's Avatar
Medic 66 Medic 66 is offline
Medic 66 is gaining momentum as a positive member of FTE.
Is this what the CCV mod took care of on the 7.3's?
Old 04-08-2010, 12:07 AM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.
Quote:
Yes its also the mod that was done on the 6.0's There will be oil residue in the bottom the CAC the amount relay depends on the total use at the time its checked.
Old 04-08-2010, 10:43 AM
Thanks for the info about the oil residue.
My truck has not had the white smoke under heavy throttle in damp conditions and it has not stumbled on "hammer down" acceleration from stop signs, merging, etc. So far, me likes how the new CAC is doing.
Old 04-18-2010, 11:39 PM
tshearn tshearn is offline
tshearn is starting off with a positive reputation.
Champ,
What dealer are you using for your service work?
Old 04-19-2010, 07:33 AM
Burchett Ford. So far, truck hasn't choked once under hard acceleration. It takes a bit more turbo on the top end to get my 5th wheel going but other than that, it performs better.
Old 04-19-2010, 05:08 PM
Good you hear. Just wondering if you were pleased with Burchett. I take mine to Two Rivers at the moment, but Burchett would be a little closer for me. I'm not at all familiar with their service dept though.
Rough idle, P0300 Code & pinhole in charge air cooler shad9876 6.4L Power Stroke Diesel 18 04-01-2014 05:46 PM
New TSB for the CAC on the Ecoboost confirmed!!! moosesp 2009 - 2014 F150 10 11-21-2012 12:39 PM
Getting brave CR3999 6.0L Power Stroke Diesel 3 08-02-2012 09:27 PM
Turbo Charge Air Cooler Cleaning? gearloose1 6.0L Power Stroke Diesel 7 05-22-2010 04:29 PM
Bypassing Coolant through Throttle Body on FI 460? cac91 1987 - 1996 F150 & Larger F-Series Trucks 10 09-28-2003 08:36 PM
Tags
73, 97, air, bed, cac, charge, coller, cooler, custom, leak, oil, powered, powerstroke, throwing, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
