Best & Worst Engines Ever Made ?!?!
#1246
If you're talking about that piece of junk that came out in 2004, I absolutly suport that opinion. We bought one new in 2004 and it was in the shop constatly. And after it was fixed, a few months later we would get a recall notice to have the stuff they had just replaced, replaced. That's right, we had one of the first to brake. I could go on for hours.
Best engines I have had:
429 ford and 340 mopar. The 340 was unbelievable. My dad never changed the oil in it (for years) and we put over 100,000 miles on it before I started to drive it. But like most old dodges, the body failed the motor.
#1247
funny how it all depends on the slice, midget sprint (USAC, i believe) cars use a 4 cylinder that is a chev v-8 chopped in half down the middle and they are screamers.
#1248
Best: Ford 4.9
Audi 2.2-2.3 5 cylinder turbo
Detroit/GM 6.2L diesel (saved my butt many times in Afghanistan)
Cummins 6BT
T444E
T700-GE-701D (GE CT-7) turbine engine used in HH-60s, Apaches etc etc.(Also saved my *** many times
Worst: 6.oh dizzle (#1 in my book)
GM tech 4 (until Chrysler bought patent and installed a improved tech 4 in wranglers)
Ford 3.8
There's much more I'm sure.
Cummins 6BT
T444E
Ford 3.8
#1249
The Pontiac and International slant fours made from V-8's in the early 1960's werent so great. I've driven both in a Tempest and Scout. Generally, an I-4 much bigger than two liters without balance shafts is a bit rough.
#1250
notice the valve cover, header config, timing chain cover and coolant intake port.
thats a badass 4 banger...a "/-4" half a v maybe?
<iframe src="http://www.youtube.com/embed/NSQLFCxuXSs" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
#1251
#1253
The Mercruiser fours are GM Industrial engines, based on Chevy I-6 not V-8 architecture. Im puzzled about the Ford 460 parts statement.
#1254
Not all of them are GM, Mercruiser built their own bigger 4cyl using pistons rods and a head from a 460. It was 230ci, and I think 188hp. It replaced the 302 w/351 heads they had been using. The engines you are thinking about are actually the old ChevyII 153ci and it's stroked cousin the 3.0L.
#1255
Give me an historical context of what era that was that Mercury Marine built a Ford-based I-4. Ford had a 144/170/200 six and 240/300. Were they basically the same and was there ever a four cylinder version, maybe based on the smaller six in Europe, for instance?
#1258
chevy 327
The chevy 327sb had to be detoned cause it was making more power than the 396bb. And chevy was having a hard time selling bb With 1990 chevy350 heads and fuel enfected and 700R4 and propane you can get close to 30mpg. And V.W. 1600 after you fix them up look at the baga 1000 the worst chevy 2.8 ford 2.9 I hated seeing a hill.
#1259
Just FYI, the 2.5 in wranglers had nothing in common with the 4 tec GM other than the displacement and bell housing pattern. It is an AMC design based off of the 4.2l straight six and has been used since 1983 - 84.
#1260
Mr. T.
I have to agree on the 4.9 liter 300 cu in straight 6 Ford.
Great motor, low on power.
I had a 1994 straight cab F150 4x4 with the I6.
It had Warn Hubs and a 5 speed standard.
I used to get 26 MPG with the dome light fuse out. Canadian Gallons.
That would convert to 21.5 MPG with a US Gallon.
I don't know if you knew about the dome light fuse. If you took it out, on 1992 to 1996 F150 it would slightly improve the miles per gallon, but it would also disable the speedometer and odometer. If the truck was new, and you did this, you could make your warantee last a pretty long time, because the milage wouldn't be accurate come oil change time etc.
I installed a small digital tack on mine. In highway conditions, if the tack would read 2000 rpm on a flat road, I was doing about 60 miles per hour.
I'm a little partial because I have a 300, but my only complaint is horsepower and the ricer sound, it needs more power (or just a turbo). But after 171,000 miles it still runs like it's new. I've never owned another vehicle but for pure ***** to the wall power I'd say the 520 CID Ford they got now is pretty bad looking, that must be why they have so many ford monster trucks...
