Best & Worst Engines Ever Made ?!?!
#166
Originally posted by Fordlover1951
Ya know how long I looked at this, trying to come up with an appropriate response without lowering myself to his level? I found it to be a physical and mental challenge, too great for my feeble mind at this hour and after a day of working with the mentally ill. But its obvious... the saying holds true, I guess...
IGNORANCE IS BLISS.
IGNORANCE IS BLISS.
#168
Originally posted by pfogle
Now don't forget guys that the GM 350 diesel was a GAS 350 Olds Rocket motor, they put 22:1 pistons in it, glowplugs in the sparkplug holes and a diesel injection system on top, BAD combo, my dad replaced a bunch of these, in caddys with olds gas engines!
The block is not the same, it's beefier but has the same motor mounts (as it did have to fit in the same vehicles), different pistons,rods, heads, crank, rockers, cam, pushrods, valves, valve springs and intake. About the only things the same as the Olds 350 would be valve covers, oil pan, water and oil pump, and the exhaust manifolds. Pretty minor similarities if you ask me.
Now if someone could list the differences between a 6.9 diesel and an International gas powered v8 with almost the same displacement... About the only real problem with the 5.7 diesel were the head bolts, use ARP bolts, problem solved.
In keeping with the thread topic, I would have to say:
Best; Almost any inline 6 produced by the big 3 (with a nod going to the solid lifter "Leaning Tower of Power" for being ultimate)
Worst; In my mind, there isn't one, if there is, it would be a shared spot. My attitude is that I haven't seen a truly bad line of motors, only stupid little problems that bean counters should have been fired for (like poor quality bolts and gaskets, and things like proper windage trays in 351C's) Doesn't matter how good the block and heads are, if a company tries to save a buck somewhere on the motor, the comsumer will find it
#170
Originally posted by Pkupman82
Any General Motors diesel engine is junk.
But seriously, try telling that to an average 7.3 diesel owner that followed his owners manual to the letter and still developed severe cavitation problems at about 65000 miles, you know the story, off warranty, block needs to be replaced, costs a ton of cash, into the 3rd year of a 4 year loan on said vehicle... Think he'd agree with you?
Doesn't make the Ford diesel a bad motor, as the fix for this was incredibly inexpensive (if done from day one). Same goes for any GM diesel, the fixes are simple, the stigma it can generate, however, may never go away.
Case in point, anyone remember Mohawk EM unleaded? To this day, people will not use Mohawk gas for fear of wrecking fuel pumps/carbs/injectors. News flash, methanol isn't used in their fuel anymore, only ethanol, and every car maker in the known universe has given the o.k. to use this in fuel on their vehicles.
Stigma, guess it can last forever in those that choose to be ignorant of fact.
#172
#173
Originally posted by droptop
As a former owner of a 1989 3.8 L Sable, I respectfully disagree with your statment about stupid little problems.
Having said that, I agree with you, it does cost the end user a ton of cash to fix this stuff after the fact, money we can ill afford to waste on something that happened to save Ford a couple of bucks. Apparently Ford will warranty this problem for up to 100000 miles, kudos to them for standing up to it.
Again, I stick with what I said, I don't believe there are any truly bad motors out there, even the ford 3.8, just little quirks with each of them.
#174
I'm glad that we can agree to agree and agree to disagree in a civilized manner. I guess it boils down to semantics and perspective. From the mechanically talented, a head gasket job is probably not that big of a deal. From the consumer point of view any engine problem strikes immediate terror, hence my definition of "bad" motor. Also, Ford only extended the warranty on this problem for people whose vehicles were built after 1993 and that was only after being pressured to do so. If your vehicle was built before 1994 (even though you were under the mileage limit) you were out of luck.
However, I must say that I enjoyed the way that car drove and handled. I always felt in control of the vehicle and it was a comfortable riding automobile.
#176
The GM diesels in Humvees do have a lot of problems, they are in constant need of attention. I know I drive em and work on em everyday (USMC) The most common problems have been head gaskets, cracked heads, and fuel system problems. They lack power big time, the biggest HMMWV engine is the 6.5 it only makes 170 horsepower and some 250 or so ft lbs of torque. That is fine in a pickup truck, but a HMMWV weighs upwards of 6000 lbs. They have 2.73 gears LS Dana 44s ft & rr with 2.1 geared hubs. Even with that gearing they still have to be put into low range before they will climb anything. I would like to see a Duramax in a HMMWV backed by an Allison 5 speed auto, now that would be a good combo.
#177
But seriously, if you are USMC, and think the hummers are underpowered, just what do you want out of them? Are you towing heavy holiday trailers? Are you testing it on a 1/4 mile to see if your most recent mods will shave a few tenths? If you answered no to the previous questions, you have already answered the questions that top brass had put to them when they made the purchase. Perhaps you would like to go back to the hummers predecessor? Perhaps you could enlighten us as to what it had for hp/tq? And really, cracked heads, head gaskets, and fuel system problems... Describes about every line of diesel motors ever produced by any company.
#178
Well this a good, fun and entertaining read first thing on a Sunday morning. I think that the Chevrolet 327,283,350 are awesome motors as are the Ford 302,351. In my opinion if you had 5 cars, each with one of these engines in it and maintained them religisouly the test would take a very, very, very long time first of all and who would be the last one standing is a debate that could go on forever and does! In my opinion it would come down to the 283 and 302 with the 283 coming out on top. Just my opinion and nothing more. Worst engine ever...Chevrolet 350 Diesel...Hands down!!
#179
ok we have over 200,000 miles on our 95 dodge dually 5 speed and we pull heavy loads with it. we had nothing done to it as far as repair work. so i guess you are going to say that cummins diesels have cracked heads and blow the gaskets all the time like those crappy hummers. dodge could outpull any gm any day of the week
#180
