1960 F100 4X4 and 4X2 Leaf Springs
#46
on
I wouldn't worry about the spalyed ubolts to much. I agree that it doesn't "look" right but it seems it has held on for this long so I doubt it will cause future problems. Making a new longer top plate would be easy and cheap. Would give you the look you want plus it would be hard to tell it wasn't factory. I just noticed something about those old factory photos today. There had been much talk about the wide lip front fender vs the narrow lip front fenders. What has been proven is that what wheels the truck left the factory with dictated what front fenders the truck got. 17.5s and 19.5s for the most part got the narrow lip front fender and 15 and 16s got the wide lip. Stu posted this info out of his master parts manual a while back. Iirc there was only one case where a 17.5 was on a wide lip fender. I think it was 1958. Anyway, back to the old photo, Thats a 1959 wearing 19.5s and has the wide lip fender which should have never happened. I will chalk it up to a promo photo.
#47
It confirms your/Stu's info for 57-58, then for 59-60 models it looks like the 17.5's were dressed with wide lip fenders. Thats the way my truck was delivered from dealer, 17.5's with wide lip! I like the way the trucks look in those photos with 19.5's and wide lip fenders.
#48
on
Thats the one Wally. Thanks for posting it again. And I see I stand corrected. So since 1959 was the first year of the factory 4x4, a F250 with the 19.5 wheel option would have been the only one with the narrow lip wheel. Just like mine
Any other 59/60 4x4 with 17.5 or smaller would have had the wide lip correct?
#49
#50
Gents,
Thanks for the input on the u-bolts.
I checked my front axle over the weekend. It does have the staggered ratios. 4:56 rear, 4:55 front. I'd heard of this before, just had never seen it.
Funny thing about the springs, I ordered a new set for the front as they are well spent and arching the wrong direction. I checked my Ford parts books and it indicated the "correct" front spring on a '60 F250 should have 8 leafs. I counted both of mine, and there are only 7? The guy that I got the springs from said his manual had option for both 7 and 8 leaf. I went with 8 leaf, but seems odd that there are so many discrepancies.
As far as the wide/narrow lip fenders go, which does mine have? I searched some images, and I'm "new" to Ford trucks, but was curious how to tell the difference between the two. Is that any way to detect which wheel size was "factory" on my truck? Sounds like it does to a degree.
Thanks fellas.
Jonathon
Thanks fellas.
Jonathon
#52
Thanks, Wally.
In the process of digging around my engine working on getting it un-stuck I noticed a tag riveted to the side of the block just aft of the oil breather down-tube.
There are several groups of alpha-numerical values, but the one that stuck out the most was "C.I.D: 312"
I will do some reading on this, but looks like a 312 may have found its way into my truck at some point in its live. I understand the only good way to differentiate the two is to measure bore/stroke or look at the code on the main caps.
Funny the stuff you discover when you get into things...
Jonathon
#54
I know this is an old thread and I am new to FTE. Just picked up a 1960 F250 factory 4x4. It is fairly complete and in restorable condition, but the front spring rear brackets are in bad shape.
Thanks in advance. I don't mean hi-jack the thread either, but this thread and only one other came up when I googled the part number.
Jonathon
Jonathon
#55
Hi Jonathan, is that truck from BC? I'm asking because a friend of mine had a yellow 1960 F250 4X4 way back when we were in our late teens, early 20's. The one in your pic looks just like the one he had. It was a very cool old truck, even then. It would be awesome if this truck was the one we used to run around in.
The history I got on the truck was that it was originally from the state of Colorado. I did find some old registration papers dated into the mid to late 70's that indicate it was there until I bought it from a gentleman in Goodland Kansas.
Jonathon
#56
#57
helm40
10-08-2018 10:09 PM
davefrommd
03-09-2017 05:44 PM
DougJ_1997PSD
05-18-2016 06:11 PM
93F150&69Stang
11-28-2015 01:31 PM
