Powertrax? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Powertrax?
Old 03-16-2010, 02:15 AM
bigrigmike's Avatar
bigrigmike bigrigmike is offline
bigrigmike is starting off with a positive reputation.
Powertrax?
do you think a power trax locker in the rear of my rig would hold up? the reason i ask is they say in some reviews "there only as strong as the carrier you put them in" that sounds pretty f'd up to me. so what do you think? powertrax or the more expensive truetrac?
Old 03-16-2010, 02:25 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
You get what you pay for, one user posted about his experience with the true trac and I'm sold on it...Getting one myself as soon as funds allow.
Old 03-16-2010, 02:31 AM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
i had a true track in a front axle that held up find to harsh abuse, i've been told to stay away from powertrax in a fullsize, and an x is about as fullsize as you can get. they work great in light rigs with 35's or less, i know it sucks that everything is so pricey for the sterling
Old 03-16-2010, 10:36 AM
Mante's Avatar
Mante Mante is offline
Mante is starting off with a positive reputation.
Quote:
Newbie question but.. when you mentioned "sterling" was that in reference to the model name of the rear diff? I have found this TRUE TRAC FORD 10 1/4 STERLING
It is specific to sterling, do you know if this is the one needed?
Old 03-16-2010, 10:49 AM
njstevens's Avatar
njstevens njstevens is offline
njstevens is starting off with a positive reputation.
I just had the truetrac installed last week. From what I have read it is the way to go, yes more $$$ but as the old saying goes you get what you pay for, so if you pay ppeanuts you may get monkeys. lol. Good luck with whatever your choice may be. If you have the $$$ my opinion obviously would be trutrac.
Old 03-16-2010, 10:51 AM
Mante's Avatar
Quote:
Ok, roughly same question to you. Where did you order them from if online and do you have the part #??
Old 03-16-2010, 10:53 AM
howler4x4's Avatar
howler4x4 howler4x4 is offline
howler4x4 is gaining momentum as a positive member of FTE.howler4x4 is gaining momentum as a positive member of FTE.
That is exactly true. And the open carrier was not designed for use with a lunchbox locker.
But ... be very careful here ...
In my book the powertrax for the 10.5 open carrier is marked as "NLA"; No Longer Available.
The available 10.5" Powertrax only fits into the Tracklok (limited slip) case.
Close. The Ex has a Ford/Sterling 10.5" rear axle. The Truetrax fits both.
I would not recommend a powetrax (or any locker) for mostly street use unless the owner is the only driver and is prepared for the non-standard handling characteristics and possible noises associated with lockers on asphalt.
Old 03-16-2010, 11:06 AM
howler4x4's Avatar
I just realized the OP is BigRigMike. You might be the exception, prolly OK for you to use a Detroit Locker. *
I think your use is too much for anything inside an 8 year old stock case.
* as long as you prep all other drivers.
Old 03-16-2010, 11:22 AM
Digger 5 Digger 5 is offline
Digger 5 is starting off with a positive reputation.
The Truetrac part number is 915A550.
I'm not a fan of insert style 'lunch box' lockers but the Powertrax version is smoother than any other type. Combine that with the stronger Trac Loc case and it could be a winning combination. Do not confuse the PowerTrax with the Lock Right (they are both made by Richmond Gear). While they both install into your factory carrier, their method of operation is completely different.
Detroit Lockers are a bit harsher than the PowerTrax but still not a terrible choice. Detroits have less harshness as they get larger and in long heavy A/T equipped rigs they are nearly invisible. I say nearly but you will feel them from time to time. I have them in both of my Jeeps with D60s (both A/T) and they are fine for any driver. My wife will drive the Jeep again. After having a CJ5 with a D44, a T-18 trans and a Detroit, my wife said she'd never drive a Jeep again.
I love the Truetrac in my X. The traction is so much better than any factory option that it will go where I need to take it. I don't NEED a locker and even a selectable would be a poor choice because I want the added traction even if I don't know I need the added traction.
Old 03-16-2010, 12:14 PM
bigrigmike's Avatar
well i guess i should go for the stronger unit since i do mob the X on all terrains that i can get my wheels on
Old 03-16-2010, 12:27 PM
howler4x4's Avatar
Quote:
Detroit Lockers ... but you will feel them from time to time
And hear them! The little clunks and ratcheting prolly OK in an Ex, lots of distance and sound deadening between the driver's ears and the diff. But the occasional/rare loud bang will scare the wits out of the unprepared. I actually got out and looked one time, expecting to see gear oil & metal on the pavement
Old 03-16-2010, 12:36 PM
njstevens's Avatar
How loud was it that you got out to check. I have not even noticeed any noise change at all. I have been told you may feel a little bit during slow speeds and high speeds, which i havent either. From what i read it was the right choice for my X.
Old 03-16-2010, 01:27 PM
The noise you get depends on the model. Detroit changed the locker in mid to late 90's and added a few shims and springs to make what is called the Sof-Locker. This design is used on nearly all models excluding any application that requires a c-clip for axle retention. You should hear nearly nothing except the ocasional bang or pop. As howler said, some have been pretty loud but my old CJ (it didn't have a Sof-Locker) was very loud and there were times I thought the rear end blew up. A Dana 35, Ford 8.8 or GM 8.5 is much louder than the 10.5".
Old 03-16-2010, 02:02 PM
x2, in a 9inch on the street with the older detroits you would swear you broke a u joit or something, like said above if you go detroit make sure that if anyone else drives it that you explain that it can have strange handling quirks even on dry pavement
Old 03-16-2010, 02:08 PM
howler4x4's Avatar
I should have been clear that the Detroit Locker was in the rear Dana 44 on a Scout II.
Which is right in the same ballpark as the rears that Digger mentioned, not like the beefier 10.5. Loud enough though that the loudest bangs will still be audible in the Ex.
I would bet that the softly sprung Ex could be taught to bark with a Detroit Locker:
Drive in a tight circle fast enough to pitch the weight to one side. Hold the throttle steady. As the inside tire lifts, it will grab and slip, and bark like a seal.
Since you can do that making a fast left turn into traffic, I expect that a lot of folks here would not be happy.
Rear End Locker 03-F150 1997 - 2003 F150 0 05-02-2015 12:32 AM
10.25 limited slip rebuild goodB0Y Offroad & 4x4 2 12-15-2008 12:36 PM
PowerTrax into factory LS diff climbhightree Aftermarket Products 2 03-12-2005 11:05 PM
Powertrax no slip in Superduty tallman 1999 to 2016 Super Duty 14 12-23-2004 09:34 PM
PowerTrax No-Slip locker installed!!!!!!!! paulg 1987 - 1996 F150 & Larger F-Series Trucks 31 10-11-2001 09:39 AM
Tags
105, 1996, 915a550, axles, duty, f150, ford, locker, powertrax, review, scout, sterling, super, truetrac, truetrax, tt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
