Brand of Gears - Genuine Gear
Anybody heard of these guys(www.g2axle.com) Planning on installing a set of gears but I just want to make sure I don't get junk ones?? Any help or anyone running a set?
What all will I need, I want to take all the parts to the guy installing it.
is this the right one for the fronts? I think mine is a D50, but all I could find was a D60?
Part Number: G/22-2034-430RX
-Dana 60 Reverse Thick 4.30 G-2 Ring And Pinion Set
-Limited Lifetime Warranty
-Computer Heat Treated 8620 Steel
-Manufactured To O.E. Specs
-Double Shot Peened
-Double Lapped
-For Use With 4.10 And Down Carrier
What does it mean by reverse thick and For Use with 4.10 and Down Carrier
Is there anything else required for the front?
Here is the rear setup. It should be a Ford 10.25, is that correct?
Part Number: G/21-2046-430
-Ford 10.25in. Short 4.30 G-2 O.E.M. Ring And Pinion Set
-10 Year Warranty
-Double Shot Peened
-Double Lapped
Anything else required?
Thanks!!
-Double Shot Peened
-Double Lapped
-10 Year Warranty
-Double Shot Peened
-Double Lapped
Thanks!!
If your replacing the ring and pinion would it matter the size?
F3fitty
07-26-2010 12:12 PM
