82 f-150 gear ratios help - Ford Truck Enthusiasts Forums
Old 01-23-2003, 07:45 PM
MEPR MEPR is offline
MEPR is starting off with a positive reputation.
Alright i would like to know what gear ratios i have in my truck. The info about the truck is in my sig. Heres the axle numbers off the driver side door jam...
14 B K
I think it has 3.73 in it but i just whant to know for shure. Thanks!
Old 01-23-2003, 08:49 PM
ecarter50 ecarter50 is offline
ecarter50 is starting off with a positive reputation.
Axle code 14 is 3.00
Old 01-23-2003, 09:22 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
What would make you think it has the 3.73's. IMO, the 300's have that low down torque that makes them feel like they're geared lower.
-Kerry
Old 01-23-2003, 09:28 PM
Alright thanks guys
cam gear ratio? southtexasidi Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 08-13-2013 11:35 PM
Rear End Gear Ratio ocala562 1997 - 2003 F150 4 01-11-2011 06:03 PM
gear ratio therigwelder Clutch, Transmission, Differential, Axle & Transfer Case 6 11-24-2010 12:03 AM
gear ratios johnboggs21 Offroad & 4x4 8 07-20-2010 04:06 PM
Gear ratio fastestbbc 1999 to 2016 Super Duty 6 11-20-2008 08:56 AM
Tags
150, 1982, 4x4, 82, f150, gear, ratio, ratios
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
