Which is good limited slip for Bronco and F250 HD
Old 03-15-2010, 11:17 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Milwaukee1979F150 is offline
Well have enough of Ford's wimp limited slip that never work. Got stuck at junkyard in F250 it have limited slip but it wasn't spin both tires.
I thought about locker but after hear negative reviews so I avoid them.
I am concerned but want avoid limited slip clutches.
I heard Trac Tru is best limited slip so can anyone say it true?
Old 03-16-2010, 08:43 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
The Ford Trac-Loc is not really that bad of limited slip in street use. The clutches are known to have a short life in some cases but if set up properly they can last for years/miles. I rebuilt the Trac-Loc in our '97 Mustang GT w/8.8 rear-end 6 years and 80,000 miles ago. Still works great. I changed the stacking order to get more clutches in so it is very "tight". If you are low on $$ consider rebuilding the existing clutches. If you have money burning a hole in your pocket or really have a need for a Tru-Trac (very nice limited slip for the money) then go for it.
Old 03-16-2010, 09:41 AM
Conanski's Avatar
Conanski
Conanski is offline
The factory LS diff in most of these trucks have the clutch discs stacked in an uneven order with two metal plates side by side.. that's why it does nothing. All you have to do is restack it with alternating plates in the bronco and in the case of the F250 axle shim it for more preload and you'll have the traction you want. This is a simple 1/2hr job with $100 in parts if you buy a new rebuild kit but it can also be done with salvaged parts from another diff.
Old 03-16-2010, 09:43 AM
lew52's Avatar
lew52
lew52 is offline
I have had a lot of limited slips & lockers , now i have a tru trac , its the best buy far , i highly recomend it.....Lew
Old 03-16-2010, 03:56 PM
Milwaukee1979F150
Isn't tru trac use gear instead clutches?
Where rebuilt kit for $100. Last time I check it was double for F250.
Old 03-16-2010, 04:22 PM
lew52's Avatar
lew52
lew52 is offline
Yes there are no clutches , gear drive , nice & smooth , positive traction ...
Old 03-16-2010, 06:27 PM
rla2005's Avatar
rla2005
Stop it Lew....you are making me drool now
Old 03-16-2010, 06:30 PM
rla2005's Avatar
rla2005
This might be what you are looking for: 10.25" TracLoc (Dana) Steel Clutch Set with Guides
ibleedblueoval
1997 - 2003 F150
02-23-2011 10:31 PM
charlierogers
1999 to 2016 Super Duty
18
09-30-2008 08:31 PM
txflyyaker
2004 - 2008 F150
18
05-18-2006 11:52 PM
fors43
1978 - 1996 Big Bronco
18
01-12-2003 02:11 AM
Vaccuum
09-28-2001 05:28 PM
Quick Reply: Which is good limited slip for Bronco and F250 HD
