How many volts to the fuel pump? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-15-2010, 10:28 PM
shaggin1 shaggin1 is offline
shaggin1 is starting off with a positive reputation.
Question How many volts to the fuel pump?
I have a 2000 F350 crew cab 4 wheel drive. V10 and a superchip. I love this truck. About three weeks ago I had a few incidents where the truck would not fire. Acted like it had no fuel. I would let it sit for about 20 minutes and it would fire right up. I guessed it was a bad fuel pump. So I pulled it into the garage, dropped the tank and changed it out. When I went to start it, it would not fire. Perplexed I was. So I switched the relays around thinking that this would be the problem, but still the same thing. I pulled the plug off of the top of the tank and cheked for power. I had only one lead with juice and it read 4.6 volts. I do not think that Ford necks dow their voltage, it should be a straight 12 volts at the fuel pump plug. So I closed the hood and went inside. Came out this afternoon and it fired up.
So, has anyone experienced this before? I am scratching my head on this one.
Shaggin1
2000 Excursion 6.8L Fuel Pump Problem JDSIMPSON55 Excursion - King of SUVs 9 03-17-2017 04:11 PM
Rear AC on Econoline Conversion kontoboy Cooling, Heating, Ventilation & A/C 11 05-03-2016 08:28 PM
1984 F250 fuel pump problems????? deputydog03 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 53 11-05-2013 03:41 PM
2.3L Will Not Start ! golley 4 Cylinder Engines 15 10-02-2013 09:53 AM
1990 Bronco will not start. dawhite12 1978 - 1996 Big Bronco 3 06-24-2012 02:58 PM
Tags
2002, 2005, 450, f150, ford, fuel, going, how, power, pump, require, requires, run, voltage, volts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
