BFG A/T's or M/T's on F-250
I have a 1973 F-250 4x4. I currently have 33x12.5x16.5 Cooper Radial LT's. I'm stepping up to 35x12.5x16.5.
I would like hear from anybody who has run the A/T's and the M/T's.
In rainy or snow conditions did the A/T perform signifinitely better than the M/T's. Or did you not notice enough difference between the two to warrent using the A/T's over the M/T's.
I want to run the M/T's for off-road, but I'll spend enough time in wet and snow to stick with the A/T's if they outperform the M/T's by a larger enough margin.
Thanks.
Eric
Thanks.
Eric
>M/T's.
>over the M/T's.
>Thanks.
>Eric
IMHO, with tires that size, it won't matter what you have on when you hit the packed snow or ice, you'll be all over the road when compared to a narrow tire like a 235/85/16. At's will out perform a Mt by a large margin for the simple fact of siping, but like I said earlier your tire size is so large that it probably wouldn't be noticeable.
I'd prolly get the M/t and park the rig when it gets lousy (Icy) out.
my .02
>M/T's.
>over the M/T's.
>Thanks.
>Eric
my .02
here check this out
http://www.bfgoodrichtires.com/bfgapp/servlet/Controller/site.catalog.Comparison?tire1=templatedata%2fcatal og%2ftires%2fdata%2fAllTerrainTAKO&tire2=templated ata%2fcatalog%2ftires%2fdata%2fMudTerrainTAKM
i hope this link works.. i don't nkow how to put one in.
John
John
The M/T does pretty well in the snow because of the tread design. I like them better than an AT. AT's are not as soft as an M/T, the soft compound is much better on ice. The M/T does better in deep snow and moderately packed snow. It also is better on ice over an A/T. The A/T does a better job on the slushy snow. My M/T's are ok in the rain, not special and not horrible, 1-10 I give it a 7. I would guess the A/Ts are a little better in the rain because of the sips. I love my M/T's and wouldn't buy A/T's. The M/T's will wear a little faster than the A/T's because they are softer. I was faced with the decision of A/T vs M/T and the BFG m/t got excellent reviews in all areas of the magazines I read. When I got them last year when there was a lot of talk about them by magazines.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
I had the BFG A/T on my Bronco for 50,000 miles. I wore them down pretty good. Personally I would NEVER buy them againg. Don't waste your money, the A/T tires perform very badly off-road. They stink in mud. The only thing they are good for are those tire swings. Go ahead and get the M/T. They are AWESOME off-road in any condition. They also provide a very smooth ride. Also they are not that noisey at all compared to other mud tires. On a noise rating of 1-10, 10 being the loudest i give them a 6!! Hope this helps. GET THE M/T!!!!!!
>M/T!!!!!!
I Agree.
>M/T!!!!!!
I Agree.
I had a set I ran them on my dodge for a while then on my f-250 35-12.50 on 10 inch wheels snow the went great wore good lasted a long time on the pavement the only problem I had was in thick gooyy mud I couldn't get them to "clean out" and I had that ol'e dodge wound tight in 3 gear (4 speed) just wouldn't clean out but going to work 80 miles round trip in 2 ft of snow the ol truck was straight as a arrow dug good
FORDS always look better when pulling a CHEVY
