Still Looking for a Radiator for my 49 - Ford Truck Enthusiasts Forums
Old 03-15-2010, 11:35 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Can someone tell me how wide a stock 48-52 radiator is? I don't have one to compare. Has anyone used a mid 70s F-150 radiator in their Bonus Built? I need one with a bottom left inlet, preferably 1 3/4 inches for my 302. It looks like a 73-77 F-150 radiator might work. The outlets are correct but the core size is 23 3/4 wide. At 18 inches high it is okay but I'm unsure how the width compares with the stock radiator and if it will fit the core support.
Old 03-15-2010, 11:50 AM
Okay, I found the stock core size. It's 21 5/8 wide and 21 inches high but I'd still like to know if anyone has used a 73-77 F-150 radiator in a 48-52 truck. Will the core support handle a core width of 23 3/4 inches?
Old 03-15-2010, 11:52 AM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is online now
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
Vern,
I dont have one but I know mr4speedford has one and its out of the truck right now. Send him a PM and maybe he can send you measurements and pics.
Old 03-15-2010, 03:40 PM
jbrittonjr's Avatar
jbrittonjr jbrittonjr is offline
jbrittonjr is starting off with a positive reputation.
I've a 50 F-3 with a 226 6 cylinder engine. That radiator measures 22 and 3/8ths inches wide by 28 inches high. I think it is original to the truck, though I had to have it recored at a local radiator shop.
Old 03-15-2010, 06:43 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Quote:
With a little fabricating you should be ok Vern. The Rad support is over 25" inside to inside. The flanges the radiator bolts to, stick out 1 1/2" on each side so the stock distance between mounting bolts is just about 24".
I'm sure you can rig a mounting system for what you need. In addition to the above, half the depth of the stock rad protrudes out past the support frame toward the engine.
Confused yet? If not let me know and I'll keep trying until you are!
Old 03-15-2010, 06:58 PM
tip49's Avatar
tip49 tip49 is offline
tip49 is a name known to alltip49 is a name known to alltip49 is a name known to alltip49 is a name known to alltip49 is a name known to alltip49 is a name known to all
Radiator
I originally was going to find a replacment rad for my '50 F1 by using a 70's F150 rad but I calculated that I would have to alter the geometry of the rad support which is integral to mounting the front fenders etc.
I ended up taking the original rad in to a rad shop and they manufactured a core and added cooling tank for my AOD. The other issue to consider might be fan clearance, I didn't have enough for the mechanical fan on the 5.0L I used from a '90 Crown Vic.
Rad shop modified rad so I had top and bottom hose entry ports.
Tom
Old 03-15-2010, 09:29 PM
Yeah, I'm confused but it doesn't take much. I'm not worried about the depth but I am concerned as to whether I can shave enough off the stock F-150 radiator flange to fit it between the 25 inch radiator support sides. At 23 1/2 that doesn't leave much room for mounting flanges...about a 1/2 inch on either side. You think that can be done?
Old 03-16-2010, 12:33 AM
I'll try to look in the next couple of days. Busy tomorrow, but I've got 70's and 80 parts trucks sitting around here that had 302/5.0 engines. I should be able to sort it out....... so watch for the next installment of confusion
Old 03-16-2010, 07:15 AM
I appreciate it. I have my eyes on a NOS 73-77 F-150 radiator at a very decent price....
Old 03-16-2010, 09:47 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
There are at least eight different radiators used on 1973/79 F100/150 V8's.
The width is between 23 & 26 inches. The height is between 18 & 24 inches.
Old 03-16-2010, 11:11 AM
HD74's Avatar
HD74 HD74 is offline
HD74 is gaining momentum as a positive member of FTE.
I must have missed part of the conversation, but this were I found mine.
1950 - Truck - Ford - Radiators Cool Craft
Old 03-16-2010, 12:34 PM
Bill,
Thank you. I've been discovering this in dribs and drabs. The one I'm contemplating is 18 x 23 3/4 and should barely squeeze in between the core support. Supposedly it is for a 73-77 360/390 V8 Ford F-150 with a manual transmission. It is 1 5/16 thick.
Old 03-16-2010, 05:29 PM
Bill, I've been discovering this in dribs and drabs. The one I'm contemplating is 18 x 23 3/4 and should barely squeeze in between the core support.
Supposedly it is for a 73-76 360/390 V8 Ford F-150 with a manual transmission. It is 1 5/16 thick.
No FE engines after 1976.
D3TZ8005A .. Standard or Xtra Cooling Radiator / 18 1/2" x 23 13/16" x 1 5/64" / Obsolete
Fits: 1973/76 F100/250 360 & 1975/76 F150 360. Without: A/C, trailer towing or Camper Special packages.
Old 03-16-2010, 07:22 PM
Vern, I took some pictures of your radiator in/around the support of my 48 F6 - which is w/o an engine at the moment.
The rad is from a 74 F100 that had a 360 and measures as you and Bill described it.
From the looks of it you'll have to play with the flanges but it should go without too much trouble. I can't find your email addy so shoot me an email at mtflat at hotmail dot com and I'll send the pics to you.
Tim
Old 03-17-2010, 11:30 AM
Tim, E-mail sent. Thanks.
Electric Radiator Fan Upgrade miashley150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 07-05-2013 10:42 AM
Performance radiator question.. Fummins hagerty_justin General Diesel Discussion 0 08-13-2012 11:20 PM
possible alternate radiators airharley 1961 - 1966 F-100 & Larger F-Series Trucks 16 06-04-2012 02:08 AM
67 f100 radiator 67 429 1967 - 1972 F-100 & Larger F-Series Trucks 6 04-28-2011 06:18 AM
Will 2 row radiator fit where 1 row came out ?? Rongold 1999 to 2016 Super Duty 5 11-10-2009 05:29 PM
Tags
226, 351, 48, 49, 77, f150, f3, ford, littleton, nh, radiator, shops, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
