Does the computer control the torque converter?
I would be VERY VERY cautious regarding programmers with the TorqShift transmission. Many of the "generic" programmers are known to cause transmission issues due to the fact that they do not truly reprogram the transmission. I'm not a tuner guy so many this unit is OK, however I'd make darn sure this is the case otherwise you'll find out how expensive TorqShift repairs can be.
Personally, I would trust some of the guys on this forum who are very knowledgeable about tuners over HyperTech. HyperTech (as with any other company) may or may not tell you all of the pros and cons of their product. The tuner may not have anything to do with the torque converter issues you are experiencing, however it may lead to even more costly problems down the road. IMO unless you really do the research and know the ins and outs of adding a tuner to a 6.0 PSD you should stay stock. Just my $0.02.
Look at post #7 for doing the re-learn on it. Lots of good info on this link.
https://www.ford-trucks.com/forums/8...eshooting.html
Yes, you saw that, but no, they do NOT learn how you drive. They learn how long each shift takes from when the computer commands the shift until the shift has completed. It then adjusts the pressures to make each shift complete in the time programmed into the computer.
