So my dang temp gage is reading nothing then it will just come alive and slowly go back up to normal then just go back to zero?
Do I need a new temp sensor or could it be some thing els?
I didnt know where to look so it on the radiator is it on the bottom?
Thanks starmilt
HMMM I dont see any thing that looks like a sensor on the radiator? but I do see some kind of sensor by the oil cape?
Where is the temp sensor or the sending unit located???
Yes it is the drivers side, sorry I didn't get back to you sooner. I typed a reply but must have hit back. The radiator that I was I was talking about checking your coolant sorry.
Are you talking about the wire was hanging behind the pump. The temp sensor should be by the front left corner of the right head in the top of the block. looking at from the front. If you ground the wire out the guage should go all the wat to hot.
Behind the A/C pump just like the pic I have a alligator clip clamped on to some small threads coming out of thr temp sensor and it was loose the alligator clip lost its bite!
So you say if I ground it out it will go red hot on the gage!
