How do you remove body mounts? - Ford Truck Enthusiasts Forums
Old 03-14-2010, 06:41 PM
pidaster pidaster is offline
pidaster is starting off with a positive reputation.
I'm getting my frame ready for sandblasting tomorrow. How do I get the rubber cab mounts off? I can't find a decent diagram but it looks like it should just pull apart once the cab is off. what am I missing here?
Old 03-14-2010, 07:06 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
I used a 7/16" coarse thread bolt 6" long. Screw it in from the top and hit it with a big hammer. The lower and upper mounts will separate.
This doesn't work for some people but it has worked for me every time I've tried it.
Old 03-14-2010, 07:18 PM
Poison Oil Racing's Avatar
Poison Oil Racing Poison Oil Racing is offline
Poison Oil Racing is starting off with a positive reputation.
You may have to spray them with some wd-40/pblaster/liquid wrench and let them soak a little bit then I find that a 3 pound sledge works well
Old 03-14-2010, 08:00 PM
Hyperactive460's Avatar
Hyperactive460 Hyperactive460 is offline
Hyperactive460 is starting off with a positive reputation.
i used a sawzall and purchased all new hardware.
Old 03-14-2010, 08:20 PM
triplecreek's Avatar
triplecreek triplecreek is offline
triplecreek is starting off with a positive reputation.
I used the method Mike0o0o0o said it worked great.
Old 03-14-2010, 09:08 PM
I used the longest 7/16 bolt I could find which was about 4" but worked. I had to greatly persuade it with the 3lb hammer but they all came out. Thanks for the help!
I took the body off the other day. Removed the engine and tranny today and absolutely everything else except the frame, springs, and tires. It's a bare bones rolling chassis!
Gonna power wash it in the morning and drop it off at the sandblasting place. I'm gonna use the Eastwoods Rust converter and sealer as it seems to get better reviews that por15.
Old 03-15-2010, 01:40 PM
hp246 hp246 is offline
hp246 is starting off with a positive reputation.
Torch or sawzall unless you are a real glutton for punishment.
Old 03-15-2010, 06:55 PM
my brother in laws neighbor works for a trucking company and uses chassis saver on all their rigs. after checking their website i found that they don't recommend sandblasting ( which i was going to do ) so for around 100.00 bucks or so i can have this guy spray my bare frame saving me a few hundred by not having it blasted.
Old 03-15-2010, 07:59 PM
Quote:
My neighbor has almost talked me out of blasting. The guy at the sandblasting company was sick so it didn't get done today.
Old 03-15-2010, 08:56 PM
...after checking their website i found that they don't recommend sandblasting ...
Link please.
Old 03-15-2010, 09:06 PM
thatsrealnice's Avatar
thatsrealnice thatsrealnice is offline
thatsrealnice is starting off with a positive reputation.
soda
might try a soda blast instead of sandblast, i understand the soda is much gentler on than sandblasting.
How do you have your CB antennas mounted? P4IN COMM4NDO 1999 - 2003 7.3L Power Stroke Diesel 22 11-03-2016 01:12 PM
Cab mounts. How to? Poly? f100today 1987 - 1996 F150 & Larger F-Series Trucks 2 05-28-2016 09:07 AM
how to remove body mount bushing dieseldodgeguy 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-28-2013 11:37 AM
front cab mounts z1121jack 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 06-22-2010 07:58 AM
how to install cab mounts on a 72 olbud 1967 - 1972 F-100 & Larger F-Series Trucks 11 01-04-2008 02:47 AM
Tags
1986, body, bushing, bushings, cab, diagram, duty, excursion, ford, front, mounts, remove, rubber, super, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
