Noisy fuel injectors - Ford Truck Enthusiasts Forums
Old 03-14-2010, 04:39 PM
bjboyle bjboyle is offline
bjboyle is starting off with a positive reputation.
My 2004 F150 with a 5.4L engine starting making what sounded like clicking lifters at about 90K miles. The dealer tells me it's just noisy fuel injectors and to just get used to it. Has anyone else run into this problem? Will new injectors fix it?
Thanks,
BJ
Old 03-15-2010, 12:04 PM
twotonka twotonka is offline
twotonka is starting off with a positive reputation.
I have a 2005 F250 5.4L and with 70K miles and have started hearing the same thing. I was told it could be dirty injectors. It only makes noise when I hit the gas. I have added an injector cleaner to see if it helps. Is anyone else having this issue or is there a bigger issue with the 5.4L?
Steve
Old 03-15-2010, 03:29 PM
I've had mine cleaned a number of times and the noise is still there. I used to only hear the noise on acceleration, but now it is there all the time.
Old 03-16-2010, 06:33 PM
aft2005exp aft2005exp is offline
aft2005exp is starting off with a positive reputation.
Yeah got the same noise in '05 EXP EB 4x4 with 97K. I ran injector cleaner through and it sounds the same, but accelerates better. Eventually may replace the 8 injectors, unless any other ideas??
Old 03-17-2010, 09:08 PM
rijrnnr rijrnnr is offline
rijrnnr is starting off with a positive reputation.
Quote:
Thanks,
BJ
Ditto on the clicking noise, but it sounds like valves on my stethoscope. Another thread by a Ford tech says Fram filters kinda come apart sometimes, and clog oil passages to the valves.
Old 03-24-2010, 04:41 PM
bjboyle -
What should "healthy injectors" sound like with the scope? I'll give a listen, and then listen for the valves..
Old 03-25-2010, 09:16 AM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Quote:
Originally Posted by aft2005exp View Post
bjboyle -
They all make noise. With a scope you will hear it clearly, even on new engines. I was shocked when I noticed the noise in my Mark VIII. It sounds just like loose valves. Live with it, get a noisey muffler or straight pipes and you will hardly notice the clicking.
Old 01-19-2011, 08:17 PM
MD2004 MD2004 is offline
MD2004 is starting off with a positive reputation.
I have an 04 F150 and i also hear a tick, It is lounder at low idle and its soft enough that i'm usually the only one who hears it but that being said it still bothered me. If it is the same sound everone is talking about, the rumor i heard is that when the motor was redesigned the surfaces on the engine and the exhaust manifold remained the same however the exhaust manifold gasket was made thinner on the inside portion. By inside portion i mean closer to the exhaust channels in the manifold. since a very minute space exist there, after some wear the gasket begins to flutter against the exhaust manifold making a small tapping sound and once the engine revs up the gasket is press outward agaist it causing the sound to fade away. i asked if the problem ever gets worse or is something i should fix and the replacement of the gasket is a job on the books slated for about 9 hours. I think that comes to more than i should pay for peace of mind. let me know if that helps at all or if it sounds like i've been bamboozled.
Old 01-19-2011, 09:17 PM
Moto Mel's Avatar
Buy a mechanic's stethescope and identify the exact location of the noise. Injectors can get pretty loud.
Old 01-19-2011, 10:10 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1 EXCURSIONATOR1 is offline
EXCURSIONATOR1 is gaining momentum as a positive member of FTE.
Does your truck have a purge solenoid? My 2003 jeep did and my bmw but not sure on the fords. It sounds exactly like lifter tick or injector noise.
Old 01-19-2011, 10:12 PM
Yes you do, found it. These suckers pulse in syc with the engine and make a tap tap tap noise
http://www.autopartsdeal.com/ford/purge_valve.html
Old 01-20-2011, 11:09 AM
davef-f150 davef-f150 is offline
davef-f150 is starting off with a positive reputation.
I had a coil go bad (#8, what a fun job!) on my 99 5.4 2 days ago, and after I replaced the coil and plug the motor was making a loud ticking noise (that I didn't have before) which got somewhat quieter as it ran. At first I thought the plug was loose, so I took it back apart and reinstalled. Still ticking. Thought it might be a 'bad' new coil, so I went and bought another. Before replacing, started again, and still had noise but not as loud. mild at idle, loudest at 1500 rpm, then quiets down at higher rpm (in park). felt some of the other coils while at idle and there was no 'noise' that I could feel. any ideas? thanks
Old 01-23-2011, 07:55 AM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is offline
enriched&beyound is starting off with a positive reputation.
Didn't ford have a recall on injectors in about 04-05 range?
Old 10-24-2016, 11:22 AM
Lorrainethef250 Lorrainethef250 is offline
Lorrainethef250 is starting off with a positive reputation.
I have an 05 F350 with the 5.4. It started making a light tick at idle (cold or warm) and it started ticing louder on the interstate. At 2000 rpm if I start to accelerate hard is when I notice it the most. is that the injector? or a loose plug? I'm a little worried about it since my last truck blew a plug.
Old 10-24-2016, 02:35 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
likely loose plug
Noisy Lifter? 300sflyer Modular V10 (6.8l) 21 03-13-2017 08:04 AM
ac clutch noisy jle70 2007 - 2014 Expedition & Navigator 0 04-18-2016 01:46 AM
Injector / Fuel rail noise schmidty_dog Modular V8 (4.6L, 5.4L) 0 04-15-2015 11:03 PM
Sound proof? SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 11 02-21-2013 02:04 AM
#8 injector "knock" Kdr358 1999 - 2003 7.3L Power Stroke Diesel 7 04-25-2012 12:05 AM
Tags
2005, 2010, 54, f150, ford, fuel, injector, injectors, loud, motor, noice, noise, noisey, noisy, ranger, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
