You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I just bought a 2003 f-250 7.3 with 150k miles. My alignment guy said the steering box needed tightening up. He did and I noticed it was a little tight turning, but didn't feel comfortable questioning him. Subsequently, there is a groan when I turn the wheel now. It's been about a month since he adjusted it.
I would try backing the adjustment off and see if it stops. On top of the steering box there is a nut w/allen head, nut is a 5/8's i beleive. Mark the allen head with paint stick or something so you can tell how much you turn it. Just loosen nut and turn allen head counter clock wise just a 1/4 at a time. If you back it off a 1/4 and it goes away your all set if not keep at it and make sure your steering wheel isnt getting sloppy.
Not to hijack the thread, but gotta ask, what is the purpose of adjusting the steering box? It won't tighten up my turning radius will it?
Thanks.
__________________ Bunky Jones, retired AF mechanic, New Jersey escapee
'02 F350 PSD 2WD Crew Cab, SRW, Short Bed, PHP tuner, 4" turboback exhaust, AEM intake, Firestone air bags, Tru Cool 4739, tranny, water and exh temp guages.
2008 Cameo 35SB3, our retirement townhouse on wheels Happiness doesn't come from getting what you want, it comes from appreciating what you have!
No, It's supposed to tighten up slack in the steering wheel. It's a last resort if you've already done ball joints, tie rod ends, and bushings.
It helped mine a some, cut the slack in half. I ended up going a half turn on the adjustment screw.
__________________ These are not the Droids you are looking for.....
Current vehicles:
2009 Dodge Grand Caravan SXT 3.8L 6sp auto - Wifey's DD
2000 F250 SD XLT SC LB 4x4 PSD Ebony and Grey 260K, TS 6-pos Chip, 6637, CCV - my DD now.
1994 F150 XL RC LB 69K 5.0L 2wd, My son's DD.
The interesting thing is I haven't done all the other things first. I'm not quite sure where that leaves me. I guess I should back it off a 1/4 turn and see what happens. I've been thinking of doing all those things but haven't got started on it, yet.
Do you think the power steering pump maybe damaged?
You could have a pump going bad, just try to back of the adjustment and if nothing changes check the pump, fluid level ok? Have someone in the truck turning the wheel and listen to the pump if it’s screaming could be the pump on its way out!
I tightened my box ('01, 160K) and it removed the slack, but the box still feels worn out. As someone pointed out, the wear all happens in the 'straight ahead' position where you do most of your driving, so adjusting the box can make it tight in the unworn areas. I have adjusted several other boxes with success, so it can work, but not on every box, every time.
In my case, the front end is tight (all parts replaced), so I may just replace the box.
I'll check it out as you say, and see what happens. It just seems like quite a coincidence that the pump started howling after it was tightened.
I really want to replace all the bushings, tie rod ends, ball joints, steering damper, u joints and will probably replace the steering box. It's a super nice truck and is worth making it run right.
Does anyone know someone in the South Central Kentucky area that works on Power strokes and really knows how to do the job properly. I don't feel capable of doing something that extensive.
Thanks,
Wayne
If you want it done right, do it yourself its easy.
You must first and always jack the front end off the ground during the adjustments. Test the steering wheel for binding as you adjust the box. Adjust it till you feel a tightness in the wheel then back off till it easy to turn the wheel inside the cab.
And always check it near the ends of travel for binding. A worn box will lock up near the ends, but still be sloppy in the middle (that sounded bad)
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see. ®
It is possible to adjust it too far and too tight. I was warned by the guy that works on our trucks not to adjust it, you can damage the whole box if you don't do it right.
Wayne: If you just bought your truck, then back off the steering adj. a little and then drive it a while. I have the same truck as you, and mine has always seem to wander a little. After I drove it a while, I hardly notice it. My plan is to put adjustable ball joints in when mine go bad.
It's a little looser but still moans a little on slow speed turns. I'm going to do a power steering flush this weekend, if all goes well.
It did increase the play in the steering, though.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
