drive shaft center support (carrier Bearing)
Vibration? 1. Check to make sure the drive shaft is assembled properly with u-joints lined up, some shafts had a "blind" spline so it can't be miss-aligned. 2. Does it look like a balance weight might have broken loose from the drive shaft? 3. I assume the U-joints were checked. 4. On my 86 F250 SC I found the replacement carrier bearing support was a different height than the original. I ended up shimming the carrier bearing I think it was about 1/8" or 3/16". Used wheel alignment shims but, washers will work.
Hi guys, just made a similar post on the F150 boards. Those who are dead set on tackling this yourself can use a grinder and cut of wheel. There is more than 1 bearing that will need to be cut, but arent too hard. just work your way from the outer bearings/in, cutting diagonally (preferably 2 cuts) and pry apart with screwdriver. Also, be sure not to cut into the driveshaft itself. Safety glasses are a must to see your work when finished
jeeperman2001
07-19-2015 05:48 PM
just another truck
17
05-08-2012 11:44 AM
SleeprLegend
12-15-2010 04:22 PM
pditmars
10-04-2009 04:35 PM
