fog light install behind grille
Old 03-14-2010, 12:16 PM
muddyford911's Avatar
muddyford911
muddyford911 is offline
hey guys, i decided to remove my grille to paint it and ended up putting off road lights behind it while it was out. despite the advice i was given to tape off the grille and leave it in place, i decided to remove it.
i modified the relay harness that came with the lights so they would turn on with the high beam switch. (i dont have high beams because of my HID's)
here's some pics:
Old 03-14-2010, 12:34 PM
Mawk's Avatar
Mawk
Mawk is offline
You are a genius!
I've thought about HID's but love using my high beams for different reasons (being cut off, brake checked, stuff like that), since I rarely use my horn. But I've been putting off HID's for this very reason, since I can't really negate spending an extra 50 for the HID with halogen. And I've thought about lights behind the grill...but have never put two and two together.
Old 03-14-2010, 12:48 PM
muddyford911
i have a whelen siren/air horn/PA for those same reasons...along with the off road lights haha
Old 03-24-2010, 04:23 PM
Bonkrr's Avatar
Bonkrr
Bonkrr is offline
Any pics with the grill back in place. I am curious to see how much light is blocked by the grill. I suspect the honeycomb grill might be better than the egg crate for this idea.
Nice mounting job by the way.
Old 03-25-2010, 11:41 AM
muddyford911
thanks bonkrr, ill take some pics later on. i just got done putting plugs and coil connectors in...and im in need of a break. check back later tonight or tommorow for some pics
Old 03-25-2010, 08:33 PM
1Fordnatic's Avatar
1Fordnatic
1Fordnatic is offline
How's the light pattern going to be with them upside down? I noticed the upside down TOP on the bottom.
Old 03-25-2010, 09:11 PM
93 mix 'n match's Avatar
93 mix 'n match
93 mix 'n match is offline
im copying this.....
Old 03-26-2010, 09:46 AM
muddyford911
i dont have any complaints. the grille doesnt block the light at all. i had the grille out to paint it and couldnt tell any difference. and with my fog light mod, i can run the high beams and fog lights at the same time which puts plenty of light down the road, and also puts plenty of light right down in front of me.
Old 03-26-2010, 02:16 PM
CHRI7S's Avatar
CHRI7S
CHRI7S is offline
Did this on my Dad's 1997 a few years back with some hella round 55w driving lights. Tapped into the high beams too. Works great!
Old 03-27-2010, 08:38 PM
TMattson's Avatar
TMattson
TMattson is offline
Looks good, do you have any completed pics with the grill back in?
Old 03-28-2010, 03:54 PM
shorebird's Avatar
shorebird
shorebird is offline
Here is a set of 6" driving lights behind the grill
Mounting bracket and lights.
Bracket fabricated to use existing truck bolts and holes.
[IMG][/IMG]
In the truck. I had to move the airbag sensor up a couple of inches.
[IMG][/IMG]
Here they are!
[IMG][/IMG]
Old 03-29-2010, 12:33 PM
EllsworthFordMan's Avatar
EllsworthFordMan
EllsworthFordMan is offline
fog light install
shorebird- Where did you get that light bar? THat looks great!
Old 03-29-2010, 07:05 PM
muddyford911
hey guys, im still workin on those pics. i've been sick the last few days...so sick i had to miss work. ill try to have them up soon though
Old 03-29-2010, 09:57 PM
muddyford911
i couldnt get any decent night shots with the lights due to rain...but these should do for now :
Old 03-30-2010, 07:13 AM
TMattson's Avatar
TMattson
TMattson is offline
Very nice! Thanks for the pics
Quick Reply: fog light install behind grille
