headers install
headers install
well got the headers installed yesterday. Man am I getting old. It took me from 9am till 6pm. that included removing one broken bolt, trmoving the A.I.R system because I had to cut the tubes that go to the manifolds. then I had to go to the parts house to get a shorter belt from the pump removal, a set of spark plug wires and had to buy a set of longer headers bolts because apparently the P.O. had someone replace a manifold gasket and probably broke off a bolt and just drill it out so it was striped, no sweat the longer boltys fixed it.
anyway, after all that then I am sore. My whole body was aching, I think I am getting old. when I was younger, it would not have taken me as long and I would have been drinking beer the whole time and would have been ready for some more today.
well yea it was. I guess I can feel a difference. There were exhuast leaks that I didnt realize that were there that are not there now, the engine runs a ton quieter. the driver side manifold was cracked almost all the way around between the two middle cylinders. The [assenger side was fine but was also leaking a little. Im gonna take it out in a bit to pick up my grandson. i will see how it runs at higher speeds.
Anyone need a passenger side manifold
the headers are the Ford Racing Shorties. I didnt take any pics because I would have broken the camera when I threw it get mad.
First had a broken bolt on the drivers side.
scraped my arms getting the diverter valves and hoses from the back of the engine that hook to the manifolds. I had to cut them to get the manifolds off. then I had to cut the hoses that connect the diverter valves to the upper plumbing. Then getting the pump off was a whole other story, which would have resulted in a broken camera as well.
Then when installing the new headers, apparently someone had a broken bolt and just drilled it out. The new header bolt would not go deep enough to catch threads so I had to get longer header bolts.
I does actually run better, I guess I can feel a difference, I just drove it around town. The spark knock is still there. That is not why I changed to headers, wasnt really expecting it to be gone but was hoping. I guess my next step is to have the injectors professionally cleaned.
Other than the usual problems though, they fit great and lined up perfect with the facory Y pipe
The driver side manifold was cracked almost all the way around
I have the 5.8 351. I got them threw Jegs. they were about 300.00 not real sure of the total. I believe SUMMITRACING also has them, but they are usually the same prices. Good luck with it. As far as the true duel, from what I am told its kinda a waste of time when a 3inch single flows just as well. Thats what I have on mine
BTW, I see we are neighbors
Be prepared to go in and re-torque the header bolts in about 1K miles. Good job on the install. Headers seem like they'd be so easy to install, but are usually a bitch. Which is why exhaust shops charge so much (if they agree to install them at all).
