1999 Ford F250 Super duty Wheel Bearing Problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-12-2010, 10:26 PM
99f250Gunner 99f250Gunner is offline
99f250Gunner is starting off with a positive reputation.
Exclamation 1999 Ford F250 Super duty Wheel Bearing Problem
I have a 99 F250 Super duty.4x4 4 wheel abs. Not dually. I just found out today the Wheel bearing hubs are bad. Now I did some research and found that my truck was manufactured in 10/98. Which means the hubs need to be thru 3/21/99. Now there is another option which is from 3/22/99. Each look the same have same measurements and everything. Difference is that the rotors (which I am replacing) are different. My question Is has anyone done this. I want to buy the other hubs (3/22/99) and rotors. and put them on the truck. being that the are 50% cheaper. Would that be a problem? Below is a web address of where I found My info . My part number options are : SP580204 and (cheaper) 515020. Can anyone help? I want to know if anyone has done this before.
1999 Ford Pickup F250 Super-duty - Front Wheel Bearings and Seals Parts -TIMKEN,PARTS PLUS BEARINGS & SEALS,PARTS PLUS BEARINGS & SEALS- Hub-bearing.com=
Old 03-13-2010, 12:42 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
IIRC, the early trucks had a different front axle. Wasn't a DANA 60.
Old 03-13-2010, 10:24 AM
Quote:
How can I tell if it was changed? It has a lift kit so I don't know if someone changed it prior to me buying it. So what your saying is that they wont work on the truck?
Old 03-13-2010, 10:41 AM
Big Goof Big Goof is offline
Big Goof is starting off with a positive reputation.
Old 03-13-2010, 02:51 PM
Exclamation
Got them from napa. I had to get the rotors also that matched the new Hubs. I need to get the spindle out though to change the u joints.... having a hard time. Any ideas?
Old 03-13-2010, 07:26 PM
TRL WGN 1 TRL WGN 1 is offline
TRL WGN 1 is starting off with a positive reputation.
I have a 99 that was built 2/99. I ran into the same problem. I bought 2 newer style hubs and 2 new rotors and switched to the new style. Total cost was less than just one of the old style hubs. Only difference was the flange thickness(newer hubs have a thicker flange). Been on for over 5K miles.
do you mean that you can't get the axles out of the spindle? You will need to pry the axle out as the spindle seal holds the axle in. You will want to replace the spindle seal as well if you are taking them out.
I just replaced my ball joints and axle u-joints today, so it is very fresh in my mind
Old 03-15-2010, 01:27 PM
"You will want to replace the spindle seal as well if you are taking them out. "
Trouble is finding them auto stores here have no clue what I am showing them!
Old 03-15-2010, 08:51 PM
Old 11-18-2010, 01:03 PM
dburt dburt is offline
dburt is starting off with a positive reputation.
Is it possible to just replace the wheel bearings on these model year trucks,or do I need to also replace the wheel hubs and rotors? Mine was made in 5/98 Thanks David
Hub Bearing assembly - OEM or Aftermarket? bossgobbler 1999 to 2016 Super Duty 14 11-08-2016 11:54 AM
Early 99 F250 Super Duty 4x4 Hub Spacers Washers olderf150 1999 to 2016 Super Duty 10 02-26-2016 11:04 AM
Early 99 hub changeout Psyclopse 1999 to 2016 Super Duty 17 10-02-2013 06:09 PM
early 99 hub conversion ???s CuNmUdF250 1999 to 2016 Super Duty 7 01-01-2013 03:37 PM
Can someone confirm that 99 f250 rotors don't fit my 01 x? MikefromMT Excursion - King of SUVs 4 08-12-2012 09:24 AM
Tags
1999, 2000, bad, bearing, bearings, duty, f250, ford, front, problem, replace, replacing, shutter, super, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
