2001 4.2L Cylinder head Temperature Sensor - Ford Truck Enthusiasts Forums
Old 03-12-2010, 07:45 PM
5speed 5speed is offline
5speed is starting off with a positive reputation.
Does anyone know if a 2001 F-150 has a CHT sensor? If it does where is it located
Old 03-15-2010, 07:49 AM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
I do not think so.
I think the first year or two (98-99) had 2 coolant temp sensors, but somewhere mid 99 model year run, or with the roll out of the 2000 model, it was changed to a single coolant temp sensor.
Pretty sure the 2001 will have a plug screwed in where the earlier temp sensor would have been.
Old 06-09-2010, 05:42 PM
Two4trippn's Avatar
Two4trippn Two4trippn is offline
Two4trippn is starting off with a positive reputation.
Mine must be a mid-year with the plug at the front sensor. Where is the second sensor?
which sensor runs 2001 v10 temp guage fordrocks96 Modular V10 (6.8l) 1 11-08-2015 12:24 PM
MAF 2001 4.2 W.O.T. 3.8 & 4.2L V6 0 08-28-2014 06:51 PM
2001 Escape Vaccum Diagram guliver Escape & Escape Hybrid 3 03-19-2011 11:17 PM
2001 v-10 p0720 paulmdahle 1999 to 2016 Super Duty 0 05-20-2010 03:17 PM
How to replace middle parking aid sensors tommybrede Excursion - King of SUVs 3 04-07-2010 09:28 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2001, 42, 42l, 98, cht, cylinder, f150, ford, head, heat, location, sensor, temp, temperature, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
