How fast does an alternator need to spin to work? - Ford Truck Enthusiasts Forums
Old 03-12-2010, 07:02 PM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
I've tried google....to many "it works as long as the engine is running" answers.
I think the alternator pulley is about a 5:1 ratio compared to the engine flywheel, so I'm guessing from 2000rpm & up.
Anyone actually know?
I'm talking alternator RPM, not engine RPM...
Old 03-12-2010, 07:51 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
2000 rpm is what came to mind for me as well, but I don't really know the answer to that question.
The faster they spin the better they work.
What is your planned use?
Old 03-12-2010, 07:58 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
DB electrical (where my alt came from) states that at enigne idle I have 115amps, and my alternator produces 220 amps at 1200 ENGINE RPM. so 2000+ before you really got anything useful
Old 03-12-2010, 09:56 PM
Quote:
Go kart.
I'v never had one that fit in my truck, so I am making one that will. The body is like a golf cart but a touch longer, wheels stick out because they are 25"tall and 14" wide, and instead of a roof or golf club holder thing it has a roll bar with offroad lights.
Ordered a 10hp diesel today.
The engine will sit sideways near the back, with a pulley (smaller pulley on motor, larger on tranny) to a 3 spd old truck transmission (pretty small), that will reside under the seats. From the transmission, a chain drive to the side of the solid rear axle. In the center of the rear axle, there is a sprocket and chain going to the front axle. It will travel under the vehicle inside some 1" steel tubing. (with idler sprockets to pick it up)
The front drive system has been tough. I've welded and hacked and cursed and started drinking several times now. I think I'll scavenge the front end from a FWD car. Because of the large wheels, there is not much room to play with in the front. I have no plans at all to try and incorporate suspension in this machine, just fat tires.
.....Anyways...
Where the belts (dual v belt) go from the engine to tranny, I plan to hack a v-belt pulley on the alternator and dual purpose it as a belt tightening / clutch mechanism. It should work, pulley on motor is 5.25" and the 1 cyl probably idles at 1500.
The only time it wouldnt be spinning is with the clutch pedal pushed, which is not really important.
I think the engine has a little alternator built in because it has an electric starter, but I'm putting 4 55watt auxilary lights on the rollbar, and another 2 55watt lights on the front, and mp3 cd player deck , CB radio, and I doubt those little built in charger things are good for 10 amps.
With all my lights on at the same time, and the stereo cranked, I bet that motor will lose a few hundred rpm's at idle LOL.
Old 03-12-2010, 10:50 PM
binuya's Avatar
binuya binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
Go kart.
.....Anyways...
That sounds sweet.
You've got to post pics of that when you get it done. I've been wanting to build a fat tire diesel mini-bike with a Yanmar clone engine.
Old 03-12-2010, 10:53 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Your lighting alone will consume about thirty amps, continuous, and you may be somewhat disappointed with the amount of horsepower the alternator will rob from that 10 horsepower unit, leaving less to propel the vehicle than you might have wanted.
Pop
Old 03-12-2010, 11:47 PM
Quote:
Pop
I'm sure with everything running the draw will be noticeable, but not enough to have to pull over.
I know 1 other guy that has a 10hp diesel, they are torquey little *******s.
I'm trying to gear it so that 60km/h (40mph?) is 3600rpm in 3rd gear...so there should be plenty of low down grunt.
Thats fast enough for offroading anyways. The exact same engine in a generator package claims "8 hours run time at full 7000watt load, or 11 hours at 50% load". Thats off 4.5 liters of diesel.
It was either this or a 20hp v-twin. I thought it might be awesome to hear the v-twin exhaust all the time, but I think this will be pretty cool. Guys on the internet have propelled small cars at highway speed using these little diesels. My little machine hopefully will run good with such low gearing. I might need some power if I hit a good mud hole. The front axle will also be solid, so traction won't be a problem as long as you don't need to go anywhere but straight ahead LOL.
PS for those of you who might notice, I am no longer pursuing a mud bogger truck. I think this will be more fun, and i'll get a lot more use out of it too. Plus now I'll be able to put a diesel in the back of my other diesel.
Old 03-13-2010, 01:29 AM
while i'm at it- anyone know how I can rig a tachometer to an engine without electrical?
is there a magnet sensor kit or something you can buy?
Old 03-13-2010, 02:09 AM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
6x55=330W the radios have minimal power draft.
All that still equals to less than 1/2 hp draw from the engine.
Even with 10hp diesel not too much to worry about.
For comparison I do have 6kw alternator on my bus conversion that I am using to power inverter to power roof AC. That is 1.5 kW=2HP draw. When the big Detroit is idling at 550 rpm and I turn AC on, I can hear slight change in the engine tune, but that is about all.
Old 03-13-2010, 02:19 AM
I think it should be fine. I'll probably barely ever use all the lights at the same time anyways.
I was originally going to live with a 5 or 10 amp charge....but it turned out the idler pulleys were 25$ each...plus a shaft, and mountings.... the alternator will do that job plus make power for just a little more.
I have some scale drawings made up. basically i'll look like a kid in a power wheels. LOL 4ft wide body aint much room.
Old 03-13-2010, 02:22 AM
Kajtek1's Avatar
Yet, judging from your avatar it will be HUGE improvement.
Old 03-13-2010, 02:43 AM
There won't be much more room, but I will hopefully have a cup holder for my liquid courage.
And I'll have lights so i find my way home instead of the bar all the time.
Old 03-13-2010, 02:58 AM
Car with 10 hp diesel jammed in:
http://www.utterpower.com/10hp_chevy.htm
"The car proved to pull the steepest hill they could find at more than 15 miles an hour with this hefty load! Flat ground produced nearly 50 miles per hour"
I'm confidently thinking my little unit should motor along just fine, while sipping on fuel.
Old 03-13-2010, 09:31 AM
Kajtek1's Avatar
That should be impressive?
This is cluster of 2 ton, 201 HP Mercedes I used to drive.
At average 67 mph it was making 52 mpg..
Old 03-13-2010, 10:47 AM
farmdad's Avatar
farmdad farmdad is offline
farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.
Talk about down-sizing.... Sounds like fun and a challenge. Could you use parts from a 4X4 ATV for the axles front and rear? Just a thought.
2002 7.3 F250 Alternator upgrade JIA 1999 to 2016 Super Duty 1 11-27-2015 01:03 AM
Alternator issues? pdqford Electrical Systems/Wiring 17 04-07-2015 04:20 PM
Alternator Question RPM371 6.0L Power Stroke Diesel 24 02-26-2014 06:08 PM
Large case 1G Alternator on 1977 F250 oldjag 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-29-2012 10:56 PM
Battery light @ high rpm bobward737 1997-2006 Expedition & Navigator 5 03-26-2003 08:43 AM
Tags
alterator, alternator, amps, bed, car, cart, charge, drawl, dump, fast, golf, make, power, rig, rpm, spin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
