Axle codes - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Axle codes
Old 03-12-2010, 01:50 PM
Shawn63200 Shawn63200 is offline
Shawn63200 is starting off with a positive reputation.
Axle codes
I have a 97 F250 HD that I am swapping from the twin I-beam to a solid axle truck. I picked up what are supposed to be the front axle from an 02 F250 and a take out 03 F250 rear. Theaxle tags are as follows.
front: top row: 3.73 (space) a delta/upside down triangle 3C34 (space) FC
botom row 611337-1
rear: top row: 3 (space) V (space) 457 (space) A
bottom: 3L73 (space) 10 (space) 5 (space) 4K21
Any help figuring out what these are/are from would be great. I'm looking at possibly putting air/electric lockers in them, so I need to know exactly what they are first.
Shawn
Old 03-12-2010, 03:20 PM
Rando Commando's Avatar
Rando Commando Rando Commando is offline
Rando Commando is starting off with a positive reputation.
The front axle should be a Dana 60, which I believe is a 9.75" ring gear. 3.73 ratio.
The rear axle should be a Sterling/Ford 10.5" full floater. 3L73 means that it is 3.73 limited slip.
Wheel / Tire Mock Up eman92082 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 01-19-2016 01:32 PM
back spacing 79F250isalive! 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-17-2014 10:29 PM
Straight axle assy worth what? craziejoker 1961 - 1966 F-100 & Larger F-Series Trucks 1 05-15-2012 09:25 PM
F150 Storage space(lack of) mnjettr 2009 - 2014 F150 20 03-21-2010 11:02 AM
Axle decoder zeaga Clutch, Transmission, Differential, Axle & Transfer Case 1 06-19-2007 05:45 PM
Tags
105, 1994, 3l73, 611337, axle, bom, cf, codes, dana, duty, ford, front, sterling, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
