1998 Expedition w/ blown motor - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 03-12-2010, 11:10 AM
Tom_M Tom_M is offline
Tom_M is starting off with a positive reputation.
I have the opportunity to purchase a clean Eddie Bauer 4x4 version w/122,000 miles on it and a blown motor. It also has a snow plow attached and I'm interested in using this truck to plow residential driveways next winter. So my two main questions are should I rebuild this engine myself or by a reman unit if so please recommend a good one or two. Secondly is the transmission in these trucks solid or do they have a history of problems? I'm just leery about doing this myself because I read about so many people with head problems on this 5.4L engine and I'm mechanically inclined (Ive rebuilt 2-stroke engines) but have never rebuilt a 4 stroke truck engine before. Did Ford ever come up with a fix for this problem?
Old 03-12-2010, 06:31 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
The Expedition is not designed strong enough to plow commercially. It is only a 1/2 ton frame. You'd be much better off with an F-350 4x4 pickup.
Old 03-12-2010, 07:00 PM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
alloro's right about the snow plow, if you check the owners manual it say's just that.
Old 03-12-2010, 08:29 PM
Alright everyone knows what the manual says and what happens in the real world are two different things. I realize it's not meant to push large amounts of snow however it can push with a smaller blade like the one that is on it. I'm 43 YO and I've plowed for years, I'm not some kid that doesn't know what he's doing. Besides I'm only doing driveways not large parking lots. Are you telling me that guys with Jeep Wranglers, Cherokees, Chev Blazer & Jimmy shouldn't be plowing with their trucks because they're less than 1/2 ton???
There's a correct application of a snow plow for almost any 4x4 vehicle, of course I wouldn't try it with anything less than 6 cylinders. I have a friend who plows with a 6 cyl Toyota Tacoma... I plow with a 1/2 ton Chevy pickup truck and an 8ft blade and my truck is no worse for wear.
I really was looking for advice about the engine reliability, and whether these were really a junk motor not worth putting $ into. I've read about a lot of the 5.4L blown up w/ less than 75K on them. Anyone with helpful information please share, thank you.
Old 03-12-2010, 08:40 PM
Quote:
I appreciate your concern, let me know where I can find an F-350 4x4 with a Snoway 7ft. plow on it for under $5K and I'll jump all over it...
Old 03-14-2010, 09:44 AM
whitefordexplorer's Avatar
whitefordexplorer whitefordexplorer is offline
whitefordexplorer is gaining momentum as a positive member of FTE.whitefordexplorer is gaining momentum as a positive member of FTE.
on your original question about the motor.... you could buy a remanufactured engine for cheap, but getting it installed is a little less fun than your average kick in the ***. but as for what everyone else says, i wouldnt trust a snowplow on that size truck, a 350 or even a 450 would be best.
Old 03-14-2010, 10:49 AM
jdecker jdecker is offline
jdecker is starting off with a positive reputation.
I think I would go with a reman or low mileage used engine versus rebuilding what you have, quicker, definitely easier and possibly cheaper. As far as plowing with it I have a friend who has been using a '97 for about 5 years now and in the summer pulls his bobcat and has never had any problems and he's over 200k on miles now.
Old 03-14-2010, 11:06 AM
cbradford cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
I had a 97 expy with the 5.4 and 192k on it when I up sized to and excursion and it still ran strong did not burn or leak oil. I used the expy for my company vehicle and carried around about 800 to 1000 lbs of tools/supplies. The 5.4 has always held up for me.
Old 03-14-2010, 02:05 PM
The Plow Guy The Plow Guy is offline
The Plow Guy is starting off with a positive reputation.
ebay has alot of 5.4's but you'd be looking around 2400.00-2800.00 from what I see listed now or theres acouple used ones for less
Good luck either way
for a side note I would'nt put the stain of a plow on my 99 navi. would get a f250 or up
Fuel filter issue advice Pheadrus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 02-02-2016 11:39 AM
OT What do you guys know about snow plows? Jolly Roger Joe 1948 - 1956 F1, F100 & Larger F-Series Trucks 130 02-18-2015 04:46 PM
New to me 92 f250 with some issues and questions, help! wr310rdr 1987 - 1996 F150 & Larger F-Series Trucks 4 07-24-2013 08:18 PM
Old Fisher Motor Mounted Hydraulic Pump JMyers0901 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 09-29-2011 08:05 PM
Headlights & Plow lights JD_F250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 03-05-2010 11:43 AM
Tags
1998, 2010, 54, 98, blown, ebay, engine, expedetionswithblownmotors, expedition, expeidition, ford, forums, lincoln, manual, motor, navigator, pickup, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
