Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 03-12-2010, 10:05 AM
Offroadracer426 Offroadracer426 is offline
Garage is empty, add now
Offroadracer426 is starting off with a positive reputation.
How much oil does a 1991 F150 XL hold? I need to replace my oil pan
I need to replace the oil pan on my truck, my brother said i need to know the amount of oil it holds, does any one know and do i even need to know. On jegs.com I found one that said it would fit, does it even matter, if Jegs said it will fit I woundln't need to know how much oil it needs should I? And do i need a oil pan gasket and bolts? Please help, thanks
  #2 (permalink)
Old 03-12-2010, 03:45 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
These trucks hold 6 quarts including filter, so the pan should hold somewhere around 5 quarts. You should be able to re-use the original bolts as long as they are in good shape, but you should definitely get a new gasket. One piece rubber gaskets from the dealer (or Fel-Pro) are the best way to go for a gasket.
__________________
Eric
'87 F150 302 ZF 5 speed 4x2
  #3 (permalink)
Old 03-16-2010, 08:51 AM
Quote:
i got a fel pro gasket, i think my gaskets why its leaking, its a small leak but it will add up. I think i'm gonna por15 the bottom of the truck. thanks
  #4 (permalink)
Old 03-16-2010, 09:58 AM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.
Yes you can reuse the bolts,the felpro is a pretty good gasket. When you place the gasket onto the pan,I usually use a couple of bolts to hold the gasket in place while putting the oil pan back on.Here's a link to the Ford Truck Oil Pan section on our site,if you also need a pan.
__________________
GREAT SELECTION OF TOW MIRRORS
Tony
1A Auto Parts
CALL ME DIRECT1-866-403-3393
Shop For: Ford Truck Parts
  #5 (permalink)
Old 03-16-2010, 10:43 AM
I Tried I Tried is offline
I Tried is starting off with a positive reputation.
6quarts it is
  #6 (permalink)
Old 03-16-2010, 11:14 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
Quote:
felpro gasket comes with plastic holders.
__________________
"To believe is to know you believe, and to know you believe is not to believe." ~ Jean-Paul Sartre
  #7 (permalink)
Old 03-16-2010, 12:36 PM
DIYiT's Avatar
DIYiT DIYiT is offline
1995 Ford F-250
DIYiT is gaining momentum as a positive member of FTE.
You can also use a bit of RTV in spots if the gasket wants to fold or bed for some reason. You don't need a lot, but it can help for those hard to reach areas to ensure the gasket stays in place.
__________________
1995 F-250 - Vortech 460, E40D - 4x4 3.55, Single Cab, Long Box
DIYiT's F-250 Build Thread
-Dana 60 Swap
-Vortech Install
  #8 (permalink)
Old 03-18-2010, 04:21 PM
Quote:
i used rtv on my intake manifold gasket, i'm not doing the pan yet cause i have to drop the tranny, that may be a project for spring break or i might do it over the summer. I don't think the pans that bad but it is rusted and i just dont wanna chance it.
Tags
05, 1991, 1995, 2002, 91, amount, f150, f250, fit, ford, hold, litres, oil, pan, quarts, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
