Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Washington Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Washington Chapter Washington Chapter
Join Chapter, Leader: Snowbunny
  #1 (permalink)
Old 03-12-2010, 03:23 AM
Brian Abington Brian Abington is offline
Garage is empty, add now
Brian Abington is starting off with a positive reputation.
Moving to spokane...emissions testing.
My wife and I are moving our family to spokane towards the end of summer.
We are really excited about this change in our lives and look forward to settling in the area.
I do have a question for you guys.
I grew up in Nebraska, and now live in Iowa. Both states do not do emissions testing.
I am rather nervous about the emissions testing in WA because of the work I plan to do to my truck.
I am installing a pair of headers and true duals (plan to put in new high flow cats so I will at least have that.)
At the same time I will work on the intake and I also plan to remove the air pump and egr.
Will I fail the emissions testing with an intake, exhaust, and air pump removed?
Or are they not that picky with trucks?
Mine is a 94 F150 ex cab 5.8l auto 4x4
thanks for any input guys.
  #2 (permalink)
Old 03-12-2010, 10:09 AM
Behemoth Behemoth is online now
Behemoth has a very good reputation on FTE.Behemoth has a very good reputation on FTE.Behemoth has a very good reputation on FTE.
From what I've figured, you're going to have a little trouble with the inspection. Not so much due to emissions, but due to equipment. According to their website, all emissions equipment must still be installed and operating on your vehicle, which from your admission that you've removed the smog pump, that's not the case.
You should probably reinstall the pump, and with the headers, probably means you're either going to have to reinstall lthe original exhaust manifolds, or have a bung welded into the headers so the exhaust recirculation pipe can be installed. Honestly, I'm not sure that the headers will fly with them even if you take those steps. The intake manifold may not pose as much of a problem, but you should still have the EGR equipment installed at the throttle as well.
You can do some snooping on their site yourself to answer some of your questions...... Washington Vehicle Emissions Inspection Program - Welcome It has just basic information, but I'm sure they're going to be pretty much as draconian as possible, so they ensure that they generate as much revenue for the state as possible (but I'm not cynical, or anything).
I have to do that this year myself on my vehicles, as I moved to Spokane last July. I'm not too worried about it as the equipment is still intact on my rigs. My beater pickup, Maynard ('88 F150 4.9L), might have an issue as it's had the engine light flicker every once in a while, but I've changed pretty much everything having to do with the emissions system. If I fail, and I've already made all the repairs possible, I'll have to get it checked by an "approved" mechanic, and if everything is in working order, I might be eligible for a waiver. That is, IF I fail the test....it'll probably be fine, as it's not a smoker, and doesn't leak, so we'll see.
Anyway, that's my $0.02
  #3 (permalink)
Old 03-12-2010, 10:20 AM
So do they have photos of what everything should look like? If they don't know what to look for and only check to see that it has cats and mufflers it may not be that big a deal.
I called a truck shop in spokane and asked the same question...the guy said they only put the emissions tester in one pipe so if you have duals you may still pass because the machine is only picking up half of what your puting out! haha
  #4 (permalink)
Old 03-12-2010, 12:36 PM
Well, if that's the case, then I'd doubt you'd have much of an issue. I'm just telling you what i found, and what I think. It's up to you what you do with that information.
  #5 (permalink)
Old 03-12-2010, 03:58 PM
I appreciate the info, I'm just trying to find all the info I can. It will be interesting to hear how your experience goes.
  #6 (permalink)
Old 03-12-2010, 05:57 PM
caseys's Avatar
caseys caseys is offline
caseys has a good reputation on FTE.caseys has a good reputation on FTE.
I have never had anyone actually look to see what was installed or not. That main thing is to pass the emissions test. Take your truck to a shop to have the emissions tested for pass/fail before going to the Washington DMV test site. Just a thought...
__________________
1996 Explorer EB AWD 5.0 & 2005 Ranger XL 2wd 2.3
Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime. ~ Ancient
  #7 (permalink)
Old 03-15-2010, 04:33 PM
really? never look under the hood or under the car even?
  #8 (permalink)
Old 03-16-2010, 08:13 PM
caseys's Avatar
Now I am only speaking from my personal experience over the years going to get our vehicles checked for bad breath. For our '96 they just plug in a doo-dad under the steering wheel. I can not remember a time that a hood was ever lifted up or someone sticking their head under the vehicle.
Maybe others can chime in with their observations...
__________________
  #9 (permalink)
Old 03-17-2010, 12:14 AM
lostmybeer's Avatar
lostmybeer lostmybeer is offline
Have a nice Beer!!!
lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.
My hood has not been opened or looked at for emissions. As the years go by, my opacity rating gets lower. Truck is straight piped with a stack.
__________________
After 10 years, its gone...2002 F350 Loaded with a lot of goods and time
1999 F350 stock as stock can get. Ignition kill switch and Trailer Brakes. Modifying underway
  #10 (permalink)
Old 03-18-2010, 12:09 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1996 Ford F-350
My Garage
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Just don't move into Spokane county, problem solved
I sent you a PM Brian Abington, let me know if I can be of help.
__________________
Chase
PAA Member #2
97 F350 CCLB 4x4 PSD
96 F350 CCLB 4x4 PSD - totaled 4/17/11 and sorely missed
God speed PaysonPSD, you will be missed
ThumperTalk / All Things Moto! / Back Country Rebels / SAWS / BRC
  #11 (permalink)
Old 03-19-2010, 05:44 AM
good to know, and superduty4x4 thanks for the unrelated info in the pm I appreciate it.
  #12 (permalink)
Old 03-24-2010, 03:17 AM
rupejosh's Avatar
rupejosh rupejosh is offline
1994 Ford F-250
rupejosh has a very good reputation on FTE.rupejosh has a very good reputation on FTE.rupejosh has a very good reputation on FTE.
spokane county sucks anyway
  #13 (permalink)
Old 03-26-2010, 04:14 AM
sucks how?
  #14 (permalink)
Old 04-05-2010, 05:58 PM
lemonshindig lemonshindig is offline
lemonshindig is starting off with a positive reputation.
sucks because they have emissions testing.
I grew up in Spokane. They don't look for emissions equipment. They plug the computer into your cigarette lighter, type in the VIN or scan it if it's a newer vehicle, and then put the tester up the tailpipe and check emissions at idle and at 25mph.
It's super, super easy to pass. If it's in tune, you'll pass.
  #15 (permalink)
Old 04-07-2010, 12:19 AM
Buzz44's Avatar
Buzz44 Buzz44 is online now
Buzz44 is gaining momentum as a positive member of FTE.Buzz44 is gaining momentum as a positive member of FTE.
Smile Smog Checkout
Hey BA if that 94 has an OBD they may hook up to that. I know thats how they check my 98F150 out. Never under the hood or in the tail pipe. Im pretty sure the OBD will give up all your sins under the hood. No OBD you pays your money you takes your chances.
Tags
brian, cigarette, colbert, county, emission, emissions, hours, lighter, moving, muddy, spokane, test, testing, truck, valley, wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
