Finally Done, Cluster Swap w/ Tach - Page 2 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-04-2012, 08:37 AM
95CWChateau's Avatar
95CWChateau 95CWChateau is offline
95CWChateau is starting off with a positive reputation.
Thanks subford!
Witnessed you to the rescue on numerous electrical questions... The pinouts for the van helped a lot.
Everything works now, but I can either have a working volts gauge or a working fuel gauge but not both. I've traced, swapped pins, digital metered and more. It must be a "forest vs. trees" issue that I can't see.
Putting the original cluster back for now as the camping trip departure is tomorrow. I'll try this one again another time.
BTW, do you folks think a '96 Bronco w/tach cluster OBDI would interchange?
Old 04-04-2013, 10:47 PM
Fox Fader's Avatar
Fox Fader Fox Fader is offline
Fox Fader is starting off with a positive reputation.
Glad to see I was some help to some folks. That was a lot of work getting that sorted out. Wish I had that kind of time on my hands now. LOL.
******** type="text/html" id="overlay_tmpl">
Old 04-05-2013, 06:09 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Wow---talk about a timely thread!
I've been considering this same sort of operation for my own '03 E250 using most likely a tach cluster from an F-Series. I'd want to rewire (so to speak) the cluster itself instead of changing the chassis wiring.
I'm fully convinced this can be done and might have just found the motivation to get my rear end into action!
As a side note here's a link to an anatomy of the '97 and up clusters from E vans: http://www.ford-trucks.com/forums/11...l#post11747876 Perhaps some of that info would be helpful to those never had one apart to that degree?
Old 04-05-2013, 03:39 PM
tabijan tabijan is offline
tabijan is gaining momentum as a positive member of FTE.
Questions for Fox Fader -
1) Did your '93 van have rear ABS and if so did the warning light work after the cluster swap?
2) Is there repetition of warning lights in the F150 cluster of warning lights that are outside the E150 cluster (either side of the steering column)?
Thanks,
Sixto
93 E150 Chateau 5.8 185K miles
Old 04-05-2013, 06:36 PM
95e150CW 95e150CW is offline
95e150CW is gaining momentum as a positive member of FTE.
1 and 3 channel ABS relies on the PSOM. If he swapped the PSOM hes fine. The 2 sets of 3 lights next to the steering wheel on the 92-96 E-series are actually part of the cluster.
Old 04-05-2013, 07:13 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
The ABS system on the 92-96 does not get any information from the PSOM or the PCM.
The ABS system is a separate system altogether.
Old 04-05-2013, 07:34 PM
It seems I misunderstood what was happening. Both the PSOM and the RABS/4Channel modules pull this information from the axle speed sensor at the same time. The ABS unit also uses that same circuit on the later units to send diagnostics info out to a connector near the PSOM. Heres the diagram.
Old 04-05-2013, 11:27 PM
Fox Fader's Avatar
Thanks,
Sixto
1) What subford said.
2) What 95e150CW said.
Old 04-06-2013, 04:48 AM
MrNightman's Avatar
MrNightman MrNightman is offline
MrNightman is starting off with a positive reputation.
Nice always wanted to do this! Good work
Old 02-05-2014, 10:08 PM
I finally took time and re-visited this project on my van and had success!
So for those of you driving vans old enough to benefit, here's what was different on my '95 Club Wagon using a '95 F-250 tach cluster from a dual tank truck.
I used Fox Fader's excellent write-up, and followed everything to the letter only to discover that the 92-93 (his) and 94-96 (mine) pinouts were different. This created all sorts of issues. Thanks to Subford's diagrams and Steve83's info from the Bronco folks (anti-slosh writeup), I made a chart using my stock pinouts vs. the new truck cluster pinouts.
Brown plug:
pin 1 move in from Grey #11 LG/Red
Pin 5 move in from Grey #6 Y/W
Pin 9 new Tach positive wire TBD
Pin 10 move in from Brown #12 BK/W (for V8)
pin 13 move in from Brown #11 R/Y
Pin 14 move in from Grey #12 R/LG
Grey plug:
pin 1 move in from Brown # 14 BK/W
Pin 2 move in from Grey #5 PK/LG
Pin 11 move out to Brown #1 LG/Red
pin 12 move in from Brown #10 BK/Y
pin 14 make jumper wire from Grey 13
Pin 14 is used to power the anti-slosh module which will only work when the fuel trace is cut on the circuit board. If the trace is cut without a powered anti-slosh module, the fuel gauge goes past full (open circuit). When you cut the trace, and install the unpowered module the fuel gauge is inoperable, showing empty. Apparently the truck clusters have the circuit to feed the anti slosh module but no harness wiring to support it. The van circuit board already feeds the 12v input to the anti-slosh module so I had a hard time figuring out why the fuel gauge would not work after the swap.
I guess if I hadn't cut the trace or tried to install my module the fuel gauge would have worked the first time, but been bouncy while driving?
Additionally, I chose to use the check engine light circuit on the face of the tach (Grey pin 2) because the van light location on the dash trim mated to the truck anti theft light circuit location. This didn't work right when I powered it.
I also sent the airbag signal to the 4x4 low light on the cluster to match the van dash trim location for airbag light (Brown pin 2)
So if I didn't mess up this write-up, this should work for you 95-96 folks if interested.
This is a neat modification, I'll find it really useful towing as I can readily target the best RPM and gearing for maximum torque on my 5.8L. Never would have attempted without you helpful folks.
Last edited by 95CWChateau; 02-05-2014 at 10:09 PM. Reason: Edited F-150 to correct F-250 donor cluster
Old 02-06-2014, 09:46 AM
perpetualjon perpetualjon is offline
perpetualjon is starting off with a positive reputation.
What a fantastic mod!! Thanks for all the detailed info everyone.
Old 05-05-2016, 07:58 PM
Payne Payne is offline
Payne is starting off with a positive reputation.
I have a 95 e150 and I believe the PSOM went out on me - no mileage, no speedo, tranny does not shift properly.
I want to upgrade to a tach dash while I am in the dash.
Will a 1996 F150 instrument panel with a tach work in my 1995 (obviously with the wiring changes).
Thanks,
Jason
  #28
Old 09-07-2016, 12:53 PM
Fox Fader's Avatar
Thanks,
Jason
Jason,
I see no one has answered your question. At this time I'm a bit out of the loop on these rigs, but I think it'll work.
Navigator Steering Wheel Swap for Non-Redundant Control Ex's: How-to Sunline Fan Excursion - King of SUVs 52 06-17-2015 07:40 PM
+++++2010 HAPPY BIRTHDAY WISHES+++++ glruff Delaware Chapter 211 07-13-2010 11:23 PM
67 Galaxie build (dial up warning several pics) monsterbaby General Automotive Discussion 43 08-18-2009 10:56 PM
Ranger has a new front! glruff Delaware Chapter 21 06-29-2009 03:08 PM
Before and after, whatca think?????? glruff Delaware Chapter 43 06-14-2009 09:33 PM
Tags
1988, 93, 94, antislosh, cluster, decoder, f150, ford, harness, module, pin, ranger, swap, tach, truck, van, working, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
