Rear Axle Vent Piece - Ford Truck Enthusiasts Forums
Old 03-11-2010, 08:55 PM
BDawg171's Avatar
BDawg171 BDawg171 is offline
BDawg171 is starting off with a positive reputation.
1977 F250 4x4 Dana 60 rear end. The left side where the rubber brake hose fastens to the axle. You have the rubber brake hose that has the brass block where it fastens to the axle. There is a threaded piece that slides through the block and threads into the axel housing.
This threaded piece is obviously a breather vent for the axle as it has a nipple on it and there was a vent hose attached to it. I took mine out as it was full of crud.
I cleaned it out, yet I dont see how this piece actually vents. I cant get any air to pass through it. Even with 150psi. It is not a through hole in the piece. I dont understand how the air is supposed to pass through it.
Can anyone explain?
Old 03-11-2010, 11:15 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
When I took mine out, there was a small hole. It had alot of crap and rust in it and did not see the hole until I sandblasted it.
Old 03-11-2010, 11:54 PM
WyoExplorer WyoExplorer is offline
WyoExplorer is starting off with a positive reputation.
I have never known the true reason for it, for mine wouldn't pass air either.
all I know after time on the Isuzoo forum, is to always leave it on, some of the guys on the forum there found out the hard way.
Old 03-12-2010, 01:43 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
E7TZ4022A (replaced C2OZ4022A) .. Rear Axle Vent
Fits: 1962/2010 Passenger Cars, Trucks, Bronco's and Econolines.
Take a nail, probe around inside the vent. There is something plugging up its tiny hole....which ALL these vents have.
Old 03-13-2010, 08:03 PM
BDawg171's Avatar
Thanks, guys. I will take it back out to try and clean it. At least I can get a new if I have to!!
Old 03-16-2010, 07:55 PM
BDawg171's Avatar
Quote:
Thanks, Buck... indeed it was plugged up with rust and a small drill bit twisted in by hand cleared out the hole. Then I blew out the vent hose with compressor to clean it out.
FYI...I suggest you all check this piece out if you have it. It should be VENTING. I had my axles out while doing my breaks only a couple of days ago, and put it back together. It was cold then. When I unscrewed this piece today to clean it out, a "wush" of air released when removed. That was just a difference of about 20* over two days (maybe more as sun was hitting axle) and it had that much pressure difference in it. Can only imagine when it gets hot under normal driving use and that vent is plugged!! CLEAN IT OUT!
Old 03-16-2010, 08:24 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
That is one of the main reasons guys will chase oil leaks at the axle and pinion seals. Only to replace gasket after gasket after gasket just to find out the vent is plugged.
Josh
Old 07-07-2010, 10:55 AM
FordTrucksKickGM FordTrucksKickGM is offline
FordTrucksKickGM is starting off with a positive reputation.
Bill can you verify that part number. I broke one of these and need a new one. My local Ford dealer says the number E7TZ4022A is no good. Not that Im doubting you, its just the guys here are never very helpful.
Old 07-07-2010, 12:45 PM
Ronzi's Avatar
Ronzi Ronzi is offline
Ronzi is starting off with a positive reputation.
Jeffs Bronco Graveyard has these vents also..
Old 07-07-2010, 10:21 PM
willydad willydad is offline
willydad is starting off with a positive reputation.
I agree that a plugged vent will cause leaks. My 74 leaked at the weld on backside of the pumpkin and at pinion seal until I cleaned the vent
Old 07-07-2010, 10:26 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
can you just run a regular aftermarket diff breather?
Old 07-08-2010, 09:47 AM
yes. anything that will let pressure out but that will not let dirt/water in.
Old 04-07-2014, 10:50 PM
PRUSue PRUSue is offline
PRUSue is starting off with a positive reputation.
Question for an old thread:
I just rebuilt my rear end and came across this vent tube and was confused at the time. The PO has clamped a rubber tube (3inches long) to the nipple and plugged it with a screw. I took that off, re-installed it, but now I'm seeing gear oil leaking (spraying) out from the nipple. Do I just let that happen (maybe I overfilled the rear end) or is there supposed to be a check valve or cap?
Also, there was split washer, not a copper washer, between the vent tube and the brass brake t-junction. Is that up to spec?
Thanks!
Old 04-07-2014, 11:01 PM
I was thinking there was a copper washer but can't be for sure. If it don't leak it should be ok.
My guess for the leaking out of the nipple vent tube is that the hose from the vent nipple is too short. It is supposed to be long enough to be able to tie up to the rear crossmember at least at a horizontal angle to prevent crud from entering the tube.
Old 04-07-2014, 11:49 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
The washer is a standard split lock washer, not a copper one.
Like Buck said, the hose should be long enough to clip to the frame.
This is a Ford 9" but the principle is the same.
brake line rubber hoses 66 4wd 66with352 1961 - 1966 F-100 & Larger F-Series Trucks 3 12-09-2016 06:43 AM
Which rear axle differential vent hose + valve? 2000 Ranger rogerranger2122 Ranger & B-Series 9 10-03-2016 10:22 PM
96 F250 fuel/return/vent/breather line(s) question pcurtice 1987 - 1996 F150 & Larger F-Series Trucks 1 09-21-2016 09:04 PM
No airflow in front vents nelsonwong11 1997-2006 Expedition & Navigator 8 11-15-2014 06:52 PM
Check those axle vents Mikeman Explorer, Sport Trac, Mountaineer & Aviator 0 05-17-2014 01:06 AM
Tags
4022, 60, axle, breather, clogged, dana, e7tz4022a, f150, f250, ford, hose, ranger, rear, remove, tube, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
