Replacement Mirror Glass for Camper Special - Ford Truck Enthusiasts Forums
Old 03-11-2010, 03:27 PM
RedDirtLandscaping RedDirtLandscaping is offline
RedDirtLandscaping is starting off with a positive reputation.
I am looking for a single piece of replacement glass for my 69 F250 Camper Special. Local parts houses get "close but not quite". We have even tried cutting other glass, but the curves are next to impossible to do. Any suggestions that are not the peel and stick plastic?
Old 03-11-2010, 05:04 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
You know you can grind your radius with a belt sander??
John
Old 03-11-2010, 10:18 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Ford did not sell mirror glass for trucks of this vintage, but the mirror head w/the glass was replaceable by itself.
Does your truck have the original 'Hi-Mount' Western Mirrors used on Camper Special's, or something else?
The original Western mirror head is 6" x 10" about one inch thick and flat. It was available in stainless, though a painted version was also available.
It has three vertical embossed lines on its backside. If this description matches your mirror heads...
C7TZ17723A .. "Western" Mirror Head-Stainless Steel / Obsolete
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
ED BENNETT FORD PARTS in Lebanon PA has ONE = 717-275-8762.
CARPENTER NOS OBSOLETE PARTS in Concord NC has FOUR = 704-786-8139.
No Ford Dealer, no other obsolete parts vendor has any.
Old 03-11-2010, 11:21 PM
redthhies redthhies is offline
redthhies is starting off with a positive reputation.
I just pulled the glass out of my west coasters two days ago and the local auto glass place made me a new one for $8...
Old 03-30-2010, 09:36 PM
Thipdar's Avatar
Thipdar Thipdar is offline
Thipdar has a good reputation on FTE.Thipdar has a good reputation on FTE.
When I was faced with replacing a shattered LH mirror, I replaced it with an old Peterbuilt mirror. Had to move the mounting brackets, but it bolted on. I also replaced the rusted mounting hardware with stainless hardware. I actually moved the RH mirror over the the LH side and mounted the larger mirror on the off side (for better off side visibility). Cats eye mirrors on each to help with blind spots.
Parked on the street in Reno one afternoon and went in to a bar to wet my thirst. When I came back out, I noticed someone had clipped my driver's side mirror. The mirror was ok, but the mounting arms had pulled loose from the body. I managed to push them back into place with brute force, while muttering "Baby, I hope you gave as good as you got".
Replacement glass for West Coast mirrors? Rasputin53 1967 - 1972 F-100 & Larger F-Series Trucks 2 12-03-2013 12:21 PM
RockAuto Now Offers Glass! RockAuto Vendor Specials, Discounts, Product Announcements & Group Buys 0 02-27-2013 02:37 PM
1953/55 windshield glass ? Dallas area 55f100tx 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-12-2011 10:06 AM
Mirrors again. Alex from GA 1967 - 1972 F-100 & Larger F-Series Trucks 2 11-22-2011 02:22 PM
Installing vent glass bigric 1987 - 1996 F150 & Larger F-Series Trucks 4 10-13-2004 10:51 PM
Tags
150, 1966, arlington, camper, campers, ford, glass, head, mirror, mirrors, replacement, special, truck, tx, wwwglass
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
