Changing Fuel Pump 6.0
On the banjo type fittings I always put just a smear of vaseline on the O rings to protect them when they slide in. Don't over due it. Thin coating.
I used the tools on all four lines and they worked fine. They come off real easy (no need for force) just clamp on the line and push tool in, at the same time pull the line towards the tool and the line will release. I had a shallow drain pan laying on my stomach to catch the fuel ( I was expecting a water fall of fuel) when just a little bit drained out, I laughed and unhooked the other lines.
Word of caution....if you are replacing just the manifold I suggest taking off the entire pump, changing the manifold and reinstalling the entire unit. I have a 4WD and it was no problem getting it out with the drive shaft there. You need to be able to torque the bolts to spec when installing the manifold, and I found out the hard way that you can't do that with filter housing part of the pump still attached to the frame. Good Luck.
Still got a problem
I got the fuel pump changed and I can hear it running but I still do not have any fuel to the top filter. Is there some way to bleed the system or is there something else that could be causing no fuel through the pump? I did blow the line back to the tank thinking that it could be plugged but that did not change anything. I have tryed cycling the key numerous times but still have no fuel.
When I changed the manifold on mine, it took more than 10 cycles of the key to clear out all the air so the engine would run smooth. I would imagine that the recommended 3-4 cycles isnt cutting it for you either.
When you cycle the key, listen to the pump. You will hear the pump go thru its run cycle and will be able to hear the air bubbles in the fuel. Listen for the complete cycle each time and continue to cycle power until this is minimized.
This cycling is how to bleed the system.
