The truth about 02 explorer Upper Ball Joints
Guys and gals, after reading multiple posts and searching for parts I am offically confused.
My question.......can you replace the upper ball joints without replacing the entire upper control arm?
I can buy what is supposed to be (oe replacement) ball joints, and can buy the entire control arm. Some posts here say they can be replaced with a ball joint press and others say no...must replace the arm.
So, what is the truth from someone who actually has done it?
Vehicle is a 2002 Explorer 4WD
Anyone help please ????
New one to me, never heard of having to replace the entire control arm. Is the 02 still the twin traction or is it wishbone type? Havn't had one that new so forgive me if that sounds like a dumb question. Ive had nothing but the twin traction and allways just changed the ball joints. Can't say on the wishbone style though if thats what it is.
ball joints
i just changed the upper ball joints on both front sides , i have a 2005 ford explorer 4wd , i only bought both ball joints, see if you can buy ball joints with (nipple where you can add grease later with grease gun) i had to buy mine without the nipple cause they only had those in stock. you will definately need a ball joint separator/installer cause the ball joint is pressed to the upper control arm.
Can you describe the process and help me out?
I still think you can change them without buying control arms, it just does not make sense.......but as noted it appears to still be confusing to many folks.
Thanks for the replies!!!!!!!!!!!!!!
: loosen the wheel nuts . raise the front of vehicle and support it on jackstands, apply the parking brake. remove the wheel.
loosen the upper balljoint nut a few turns . using a balljoint removal /installation tool separate the ball joint from the upper control arm & steering knuckle. remove the nut and separate the upper control arm and balljoint from the steering knuckle.
separate the balljoint from the upper control arm with the ball joint removal/installation tool. you may need to turn the steering all the way to the left or right to give you more room to work with the ball joint removal/installer tool.
installation is the reverse of removal.
tighten upper arm ball joint to steering knuckle nut to 41 ft. lbs
youtube.com website has a lot of great -how to- videos on this subject.
good luck and god bless
jesse from nc
jesse from nc
jesse from nc
jesse from nc
Thanks!
I work for a company that makes control arms. Most of the newer control arms you DO have to replace the whole control arm because the ball joint is made into the control arm. I have a 2002 explorer and on this particular model you CAN replace just the ball joint. The upper control arm is stamped steel and the ball joint can be removed as you would with any other ball joint and replaced. If you take a look at advanceautoparts.com you will find that the upper balljoint sells for around $23.99.
Suspension Ball Joint by OE Brand - Part S-104268 - Advance Auto Parts
Experience with ford explorer upper ball joints..
well I just thought I'd add my experience with the upper ball joints on the 2001 ford explorer sport..
I recently replaced both driver & passenger sides upper ball joints for a customer.. at first look the control arm & ball joint looked separable; when calling in parts' the parts dealer told me that the A-Arm & upper ball joint is sold as one piece.. I told the parts dealer that i had already removed the ball joint from the A-Arm; and that it is in two pieces.. I ordered the replacement ball joints, and installing them on the A-Arm (control arm); the ball joints didn't fit..!! I did some research and found out that the OE Control arm/ Ball joint isn't supposed to be disassembled it is as one piece, it's recommended that you replace the whole control arm w/ ball joint.. the new control arms- other then the one that came on the vehicle; you'll be able to change "just the ball joints" once the OE control arm is replaced with a after market one..!!
Most of the OEM control arms & individual ball-joints don't have the grease fitting on them.. also some of the new control arms w/ ball-joints & individual ball-joints come with a different dust boot color like orange or blue, but they still do come in black..!!
for what its worth
i recently replaced the upper control arm as an assenbly in my '04 explorer. inadvertantly i had stripped the stud that goes through the control arm.
i removed the ball joint from the replacement arm and installed a replacement ball joint. i also had to tighten the nuts on the ends of the shafts which had loosened up.
taking the car for a ride, the ball joing "popped"out of the control arm.
i re-installed the factory control arm with a new MOOG ball joint and all is well.
im my experience, the ball joint can be pressed out of both the factory and replacement arms. and can be replaced accordingly. Just be wary of a certain chain store`s ball joints.
the MOOG joint i uinstalled is just a hair oversized and is greaseable, so i forsee a long life.
