Interior mods? Picture thread for pre-97 interiors.
#61
thanks man,
by the way your blue bandit is sweet.
Im looking at tearing out my bronco drive train and put it in my truck, 9" rear end with 3.73's.
Right now im running 3.55's front and rear. i know alot of people hate the TTB set up but I love it, with no sway bar it handles awesome. not to mention it rides nice on the highway.
I do want to install some Lock Rights but im not sure what to go with
and what is your truck? a 9" rear end wont bolt up in place of the 8.8 in the newerish trucks...look on your rear diff if there are wires and a little sensor on the diff housing it will be lot more work to get a 9" in there...and the 9" isnt any stronger than the 8.8 it just has more aftermarket support...a sterling 10.25 1 ton rear end WILL bold straight up in place of your 8.8 and then you can swap the front over to dana 50 TTB 8 lug hubs and be done with it...
nice interior nighthawk...i like seeing the lights hidden up under the dash/seats just to throw that glow through the cab, i got the idea from the big rigs i see...thats a very common mod in them things
#62
Thanks man, i got some in the front where your feet goes, and also white LED in my camper, and thats all i have for now i going to but some 194 Bulbs for the club compartment, and the the doors.
#63
Looks good
#64
But go ahead it will fit
If you like to know which i have, i have a Jensen VM9312HD
#65
#66
#67
I used the tracks that were on the seats. I modified the mounts to fit the floor.
The seats have the inner belt attached to the seat, so I had to make the seat a solid mounting. Under the carpet, I bolted a piece of 1/4"x2" flat bar across the floor, using the original seat bolt holes and belt mounting hole. There is also a piece of flatbar bolted to the floor for the front mounts. I made new mounts that are welded to the tracks so they bolt to the flatbar under the carpet. I was limited for head space, so I had to keep the seats as low as possible.
#68
I really wanted those gauges but the Lightning speedos go to 120 and I could only find the 80 mph ones
#69
#70
#71
#72
so I havent changed any light bulbs in my dash yet... but I did remove the queer neon lights (the 17 year old I bought the truck from had installed....they blinked with the stereo....pretty trippy) then I removed all the live wiring, and the charged unused 1.5 farad cap siting under the seat. Next was the completely unsupported cd player in the dash, it had rattled and cracked most of the surrounding plastic. I cut all the cracked plastic out and then installed a double din head unit. Then came the headliner, I pulled out and carefully removed the fabric. Then I went to the fabric store and bought some material. Some foam, and some "elephant suede" so it was called. I layed out a flame pattern in foam and glued it down then covered it in the suede. then I removed the trim pieces in the dash and covered those in the same material. Looks great and super easy. I know what your thinking... where are the pictures? Maybe one day Ill get to it.
#74
well i have the Mark III conversion to start with
center light bar:
door panels:
theres more but i dont have good pics of it
now onto what ive done
where the ford oval is the PO had an mp3 mount and i scratched it to hell trying to get rid of it so i found a good way to cover it up, the blue deal hold my phone and i can hook it into my radio to play music. the screw was already there to mount the wood
put a lock on the ammo dump i mean center counsole...
mounted my cb on the ashtray cover with clips so it still opens
mounted my Tom-Tom and radar detector up top and got power from the light bar
my lovely Cabelas finds ( savage .22 long rifle and cammo seat back gun rack)
( theres a reason professionals dont use paint lol)
center light bar:
door panels:
#75
i like all of the trucks here. i have my blue led lights for the gauges like 9ford 5 had. i got my lights off of SUPER BRIGHT LEDS - LED Lights & Accessories i was wondering if anyone who has an extended cab has a low back seat and if their raised it up and how? ii got a 93 f150 and my seat is low in the back and my friends 94 is high in the back so he can put subs under their and thats what i want to do. and i have bench seat in front and i also want to get captains chairs in the front and a center counsel.
