Reverse Lights / Fuse question
Old 03-11-2010, 09:59 PM
jls8177's Avatar
jls8177
jls8177 is offline
Hello all,
I bought a 99 f350 a few months ago. The reverse lights haven't worked on it since I got it. The bulbs are good. Can someone tell me which fuse runs the reverse lights? Or does someone have a diagram of the fuse boxes? I don't have the manual to look things up.
Any help is appreciated.
Jason
Old 03-11-2010, 10:21 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
Stop lamp fuse is #13 under the dash
You can download an owners manual with diagram here
http://www.motorcraftservice.com/pub.../99f23og4e.pdf
https://www.fleet.ford.com/maintenan...ls/results.asp
Old 03-11-2010, 11:49 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Old 03-12-2010, 09:56 AM
jls8177's Avatar
jls8177
jls8177 is offline
Thank you everyone. I'll look at it this afternoon and post back if I have any issues.
Jason
Old 03-12-2010, 01:05 PM
jls8177's Avatar
jls8177
jls8177 is offline
I checked the fuses and all was fine. I'm a bit ignorant with wiring diagrams. Does anyone have a simplified way to check the wiring that I can understand? Thanks for any input.
Jason
Old 03-12-2010, 02:59 PM
SpringerPop
The diagrams have the wire colors and pin numbers, etc, and are a pretty-good resource.
There is a switch that closes to provide power for the back-up lights when you put it in reverse, however it's different depending on your transmission (which you didn't mention).
Here's the wiring diagram for the back-up lamps circuit:
http://www.e-toolbox.com/ads/wiring/va112365.pdf
Could you get a friend who does understand to help you out with this? It might be helpful for him/her to have these diagrams printed out.
Pop
Old 03-12-2010, 04:34 PM
jls8177's Avatar
jls8177
jls8177 is offline
Thank you Marv, I'll ask around.
Jason
TxFire76
2015 - 2020 F150
10-31-2016 08:28 AM
elvia
10-05-2014 11:17 AM
eyball
1983 - 2012 Ranger & B-Series
32
05-26-2014 02:51 PM
grec-o-face
12-28-2013 09:49 AM
ChrisLambert
Electrical Systems/Wiring
07-09-2004 01:56 PM
Quick Reply: Reverse Lights / Fuse question
