1991 F250 Delay Wiper Problems - Ford Truck Enthusiasts Forums
Old 03-10-2010, 09:27 PM
JimLongusa JimLongusa is offline
JimLongusa is starting off with a positive reputation.
Just bought a 1991 F250 with a 7.3 liter diesel and my delay wipers don't work. Turning the wiper switch to low position doesn't work either. They only work in Hi with a bit of a delay between cycles. Replaced the switch and bought a used wiper delay module from a guy in Pa. It didn't seem to help. Any ideas, suggestions, or wiring diagrams would be greatly appreciated....
Old 03-11-2010, 12:03 AM
dyoungen dyoungen is offline
dyoungen is starting off with a positive reputation.
I had the same problem when I bought my 1987 F250 Diesel. There is a black box behind the wiper switch. I don't know if that is the delay module or not but that fixed my problem. The auto parts stores don't have a listing for it. I ended up getting mine from the local junk yard.
Old 03-11-2010, 12:11 AM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
When the wiper switch is in Hi, 12 volts goes direct to the wiper motor.
When Lo speed or delay is selected, the power for the wiper motor comes
from the wiper delay module which is know to have cold or cracked solder joints
on the circuit board.
Here's the schematic for a 88 with delay wipers.
The wiper motor and delay module is the same for 87-91 so I would think the schematic
is the same.
Sparatic wiper delay 94 f150 turnkyle 1987 - 1996 F150 & Larger F-Series Trucks 5 12-31-2011 11:53 AM
Adding delay wipers? dmanlyr 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 09-27-2011 12:17 PM
Windshield Wiper Switch ZukBox II 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-11-2010 03:01 AM
Adding delay wipers? dmanlyr 1987 - 1996 F150 & Larger F-Series Trucks 7 05-21-2010 04:51 PM
wiper delay not working ol74hb 1973 - 1979 F-100 & Larger F-Series Trucks 19 12-23-2009 10:07 PM
Tags
87, 91, black, board, box, circuit, delay, deley, direct, f150, ford, motor, problems, schematic, switch, wiper, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
