1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Water In Fuel light keeps coming on...
Old 03-10-2010, 08:56 PM
TXHillCountry's Avatar
TXHillCountry
TXHillCountry is offline
My "water in fuel" indicator keeps coming on, even though I've drained the water/fuel separator several times.
Is there some other serviceable part of the unit that can be bad? Sensor?
Thanks,
TX
'03 PSD
Old 03-11-2010, 05:54 AM
weldman's Avatar
weldman
weldman is offline
Did you change the filter as well?
Old 03-11-2010, 06:07 AM
Surge08's Avatar
Surge08
Surge08 is offline
Agreed as it states in your Owners Manuel as well when this happens
Old 03-11-2010, 07:56 AM
aldridgec's Avatar
aldridgec
aldridgec is offline
If you have a repeated light and have drained the HFCM, there is a problem with the harness or sensor IIRC that causes the light to come on repeatedly.
Old 03-11-2010, 08:39 AM
TXHillCountry
Had not changed the filter on the HCFM, but will do that now. Strangely enough, in my manuals section on the warning indicator lights, it just says that if the warning indicator comes on, then the HCFM should be drained, nothing about the filter. But if you go to the back section on the maintenance guide, it does say to replace the filter. Go figure.
Thanks guys
TX
Old 03-11-2010, 11:19 AM
Buckholz's Avatar
Buckholz
Buckholz is offline
My sensor corroded. Easy replacement, the new one comes with directions. Just make sure you securely tap the new sensor in like it says with a mallet. If it doesn't seat well, it will pop out on a dirt road at 9,000' elevation in a remote part of colorado...... you probably don't need to know why I know.
Both filters need done every 30k if I remember right. The HCFM one is a bit of a pain to change on a 4wd.
BTW, if you replace the sensor, make sure you stick some q-tips in the hole and clean out all the gunk/rust before you install the new sensor.
I think the sensor was less than $10...
Old 03-11-2010, 12:05 PM
rjfetz1's Avatar
rjfetz1
rjfetz1 is offline
That was an on going issue with my 06.....every month in the winter I had to take it to the dealer so they could replace the sensor under warranty of course. It never ended along with the turbo and a few other stuff and that truck is long gone. Nutin but a headache.
Old 03-11-2010, 02:05 PM
A H DEVELOPMENT's Avatar
A H DEVELOPMENT
A H DEVELOPMENT is offline
Is there anyway that the sensor could go bad and the dash light not come on at all, or is it designed to where a failure will trigger a repeated "water in fuel" dash indicator?
Old 03-11-2010, 08:21 PM
elee3's Avatar
elee3
elee3 is offline
Read post #15 by Tim C https://www.ford-trucks.com/forums/8...uel-light.html
My WIF light wouldn't go out and I performed this procedure. I flushed all kinds of nasty crap out of there and the light went out. I plan to start doing this when I change fuel filters.
Old 03-11-2010, 08:35 PM
mojo1's Avatar
mojo1
mojo1 is offline
Mine has done that some come on and off several times and after draining it a few times it would clear up. thanks elee3 for the info.
Old 10-04-2010, 02:56 AM
Tee Gonzo's Avatar
Tee Gonzo
Tee Gonzo is offline
Where is that sensor located??
Old 10-04-2010, 08:05 AM
TXHillCountry
The sensor is on the driver's side frame rail, as part of the fuel filter assembly.
I had a follow-up post..
Update on Water-in-Fuel indicator light - Ford Truck Enthusiasts Forums
which shows how I cleaned it out, and it now works fine. Bottom line is that you need to get a VERY large Q-tip (pic in the link), and get in there and clean out all the junk. It may take a couple of times to get it all cleaned out.
Rgds,
TX
Old 10-05-2010, 01:40 PM
TMF250's Avatar
TMF250
TMF250 is offline
Trailering
I have a 05 F-250 with the 6.0 Diesel and had the same problem with the "water in fuel" light coming on each time I made a hard left turn. Went to the dealership and there was a recall on the HFCM unit to be replaced due to this problem. That was 120,000 miles ago and the trouble light has yet to re-emerge since.
BTW . . . . I change both my fuel filters after every other oil change (4500 miles).
Old 10-05-2010, 01:50 PM
chipper's Avatar
chipper
chipper is offline
Flush the gunk out of the sensor pocket like "ellee3" said. Unless you enjoy throwing your money away. Took 5 minutes and I haven't had any problems.
Old 10-05-2010, 02:52 PM
TMF250's Avatar
TMF250
TMF250 is offline
Trailering
It was covered under warranty at the time. No money out of my pocket. No problem since then. But I will keep it in mind the next time I have that one filter changed out.
Stevenmcm
06-16-2013 04:37 PM
hdfxrusa
02-09-2012 06:59 AM
SUPERDUTY_08
6.4L Power Stroke Diesel
01-27-2011 06:08 PM
Caseylynn
04-09-2007 09:40 PM
lawndawg
01-14-2007 07:30 PM
Quick Reply: Water In Fuel light keeps coming on...
