Not sure what to think...
Hello everyone,
I have an 06 F350 5.4L V8. I recently (well someone else) noticed oil on the driveway! I noticed the other day that my oil was running around 1 qt low so I added some, it ended up being too much so I went under to drain some. When I was below I noticed:
- An oil leak. There's a pan behind the drain screw that appears to be seperate from it (may be the oil pan) and the screws on it are leaking oil to things below it. Which appears to be part of the transmission (the bell housing?) Not sure if the oil is leaking above the rear oil pan screws but... hopefully not.
It appears as though the oil pan screws are leaking oil, tightened them up the other night with no help. They were tightened with decent pressure so I guess they were loose but don't know if I should try tightening them more? ? ? till they stop moving?
Anyone got any thoughts or experiences such as this?
Just bought the truck 3,500 miles ago with 48000 on it now.
Hoping it isn't a leaking head gasket....Not even sure where to look for this problem, maybe a leaking gasket?
Looked at it again and noticed that it doesn't appear as though above the seal has oil, seems like around the bolts are leaking
If you think it is a rear main oil seal
does it just need another gasket seal?
Anyone ever done that?
I did tighten the oil pan rear bolts should I loosen them back, they weren't dead tight to begin with but I did end up making them tight enough that it took a little effort with a 3/8 wrench to turn it , so still not dead tight
I've got around 20K miles on it sicne the change, and no leaks.
JL
Pull the transmission out.
Pull the flywheel/flexplate.
Pull the rear seal plate.
Remove old main seal.
Replace with new main seal.
Put everything back.
It's a good day's labor by yourself, and is a good time to service the trans since you'll need to drain the pan on the trans to keep from making a helluva mess with trans fluid.
More info on the job in this thread:
https://www.ford-trucks.com/forums/8...placement.html
JL
Clean out the valley with simple green or such, and put some miles on her and look back in there, you may find the leak.
I may be wrong, but its a very common misconception.
sorry for the
