89 300 straight six issues!!!!! - Ford Truck Enthusiasts Forums
Old 03-10-2010, 08:35 PM
89straight6 89straight6 is offline
89straight6 is starting off with a positive reputation.
ok well here we go... i have a 1989 f150 straight six. from day one of owning this truck ive had ignition issues. it has new plugs an wires, distributor w/cap an rotor, new fuel module (on the side of the distributor), a new coil, new high pressure fuel pump, fuel pump relay, and the mechanic before me had replaces all the electical connectors that go to the injectors. After i fixed the leaking injectors and bypassed the fuel water seperator, the truck ran great. i put exactly 191miles on the truck and never had a problem. I was certain that i just rain out of gas, cuz of the 11 mpg that it averaged out to be, but i put gas in it and not i cannot get it started again...... I am at a lose here! i can NOT figure this thing out. if you have any ideas where i should begin to look, please let me know..... Thanks!
Old 03-10-2010, 09:47 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
When you tested for spark what was the result of the test?
"Key on" power to coil and injectors etc etc?
When you tested for fuel volume and fuel pressure what was the results of the tests?
If fuel delivery system up to spec, spark plugs wet with fuel? or bone dry? Do injectors actually cycle, in other words power to them but can you hear/feel them clicking computer is giving command to pulse?
Check to verify timing was on as in #1 cylinder up on to tdc on compression stroke, rotor point to number one on the cap?
What you replaced in the past gives us nothing to go on for a currant "no start" condition, any test results you just preformed would provide info for us to give "next step" suggestions based on the outcome of those simple tests.
Old 03-11-2010, 01:17 AM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
what he said...
also if you put some gas on your air filter bolt the box shut and it fires up then dies again that will narrow it down a bit too
process of elimination man
Old 03-11-2010, 01:55 PM
got to the truck this morning and it fired right up! drove it a little over a mile and it did the same thing. acted like it ran out of gas and just died......
PS yes there is gas in it
Old 03-11-2010, 02:07 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Quote:
Huh?
The what?
Here's what I would do:
- Pull the codes. They may lead to a sensor that's out of whack and giving bad data.
- Check the timing.
- Check the fuel pressure. This will eliminate the fuel system as the source of the problem.
You say that this truck has had ignition issues for a long time and you give a long list of ignition system components that you've replaced. But you never mentioned what the problem was or if it's similar to what's going on now.
Also, if you replaced the ignition module, did you replace a gray one with a black one or vice versa? The color needs to match.
BTW I have an '89 F-150 with a straight six.
Ignition, Timing, or Fuel Issues mphurlbert 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 10-03-2014 08:04 PM
Please assist me with this problem shocker25555 1987 - 1996 F150 & Larger F-Series Trucks 3 09-30-2014 12:25 PM
1990 f150 ef1 straight six runs extremely bad, cleat harp 1987 - 1996 F150 & Larger F-Series Trucks 3 06-03-2013 11:16 PM
No Spark to Plugs ddsvi 1987 - 1996 F150 & Larger F-Series Trucks 64 04-29-2011 11:17 PM
Injectors wont spray (89 Ford F-150 5.8-Auto) 89ford71 1987 - 1996 F150 & Larger F-Series Trucks 4 03-20-2011 12:37 AM
Tags
1989, 300, 89, checking, compression, distributor, f150, ford, inline, problem, problems, reviews, starting, straight, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
