1999 F250 Super Duty feels like warped rotors but not - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-10-2010, 07:37 PM
jaggermk jaggermk is offline
jaggermk is starting off with a positive reputation.
I have a 1999 Super duty 7.3 diesel 4x4 that has recently started to feel identical to warped brake rotors. I changed the front rotors and still have the same problem. The brakes pads are fine and the brake fluid is up to level. It seems to get worse as the brakes warm up.
Any suggestions?
Old 03-12-2010, 06:44 AM
Rick3 Rick3 is offline
Rick3 is starting off with a positive reputation.
Hey, did you ever answer this problem. I got the same on my 05 F-350. About to by slotted/drilled rotors for all 4. got any advise Rick
Old 03-12-2010, 07:06 AM
Fordsflylow's Avatar
Fordsflylow Fordsflylow is offline
Fordsflylow has a great reputation on FTE.Fordsflylow has a great reputation on FTE.Fordsflylow has a great reputation on FTE.Fordsflylow has a great reputation on FTE.Fordsflylow has a great reputation on FTE.Fordsflylow has a great reputation on FTE.
I changed out my sway bar bushings, front and back, which improved it somewhat but I noticed that I have some slop in my pitman/drag arm link end and the tie rod ends. Far as i can tell they are factory originals and with nearly 160,000 mi I suppose it's about time for a change. I have a new set of tie rods just need the new drag/center link.
Might be worth a check on your part.
Old 03-12-2010, 11:31 AM
brains06's Avatar
brains06 brains06 is offline
brains06 is starting off with a positive reputation.
Youre on the right track. Regardless of vehicle if your tie rod ends start to go they will shake like Beyonce when you brake. Swap them out and you'll likely fix your issue.
Warped front rotors - warranty? Bushwhacker1 2009 - 2014 F150 31 Today 02:38 PM
Super Duty brakes pulsating jjc103 1999 to 2016 Super Duty 8 01-07-2014 03:47 PM
1999 Ford Expedition ABS Malfunction, HELP!!! stevie624 Expedition & Navigator 10 12-08-2012 06:37 PM
Warped rotor question Rusty_S General Automotive Discussion 12 09-29-2010 07:44 PM
Brake Pads: Hawk LTS -vs.- PF Ceramic?? Racecarhauler 6.0L Power Stroke Diesel 7 10-20-2009 12:12 PM
Tags
1997, 1999, 2004, arm, bar, clunk, drag, duty, explorer, f150, f250, feels, ford, rotor, rotors, super, superduty, sway, warped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
